Date/Time: Mon, 03 Feb 2025 13:48:53 +0000
order(s) display
View Count: 745
[2019-11-13 18:54:42] |
User630795 - Posts: 92 |
when I enter order on charts (w/ chart trade mode on and order display on), it does not show on the trade dom and vice versa. however, in simulation mode, they work (show order on both chart and trade dom) fine. what am i doing wrong?
[2019-11-13 22:46:06] |
Check everything described in this section here: Chart Trading and the Chart DOM: Viewing Orders and Trade Position on the Chart / Trade DOM Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-11-15 15:57:13] |
i checked per your suggestion/instruction. everything looks fine. like i said, what is puzzling to me is...it works fine in "simulation' mode but not in "trade" mode.
[2019-11-15 22:21:57] |
Make sure the Trade Symbol (would normally be blank) and Trade Account are set identically between the chart and Trade DOM: Chart Settings: Trade and Current Quote Symbol (text box) (Chart >> Chart Settings >> Symbol >> Symbol menu) Basic Trading and the Trade Window: Main/C >> Trade Account (Selecting Trade Account for Chart / Trade DOM) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-11-15 22:22:29
[2019-11-20 03:04:50] |
different trade account was assigned to some charts. not sure how this happened and did not know that you can assign different account numbers to each chart. there should be a way to sync trade account number on charts.
[2019-11-20 03:26:01] |
. there should be a way to sync trade account number on charts. Yes there is. Through Trade Window Chart Linking:Working With Charts: Chart Linking Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-11-20 03:26:11
