Date/Time: Mon, 03 Feb 2025 11:00:43 +0000
Horizontal Line at time- Weekend Issue
View Count: 922
[2019-11-13 18:06:12] |
User190501 - Posts: 96 |
Hi Support. Horizontal line at a time - doesn't extend Friday VWAP close Value to Open in Sunday and it switches to use the new VWAP value at Sunday Open .. Though the Time to 1 Day option is set to No ? http://www.sierrachart.com/image.php?Image=1573668269577.png I am using the latest version 64-bit 2007 (28959:28961) |
2019-11-13 12_49_27-Sierra Chart 2007 Energy.cht CQG WebAPI.png / V - Attached On 2019-11-13 17:57:58 UTC - Size: 128.83 KB - 372 views 2019-11-13 12_59_20-About Sierra Chart.png / V - Attached On 2019-11-13 18:00:11 UTC - Size: 6.12 KB - 261 views Attachment Deleted. |
[2019-11-14 00:04:44] |
What is happening is that the study considers a bar to be the Start Time if that bar is greater than the given time and the previous bar is less than the given time. In order to not have that happen, set the Input for Use Allowed Range for Match in Minutes to Yes and then set the Allowed Range for Match in Minutes to the bar time or less. We have updated the documentation to make this more understandable and to include the information for the above Inputs. Refer to the documentation here: Horizontal Line at Time Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
