Date/Time: Thu, 25 Apr 2024 03:41:10 +0000
VbP (for ES) on weekly/daily charts can only go as low os 5ticks/volumebar?
View Count: 962
[2019-11-13 14:27:29] |
User873520 - Posts: 14 |
Is this the lowest it can go?
[2019-11-13 16:57:42] |
It can be set as small as 1 Tick, but you must have another factor that is causing it to not change. Refer to the information for this setting here: Volume By Price Study: Ticks Per Volume Bar Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-11-13 18:18:55] |
Thank you. I changed the chart settings to Volume at Price Multi. to 1. Then I adjusted the VbP to 1 tick and the attached screenshot is what it is showing. Looks like blocks with volume numbers the exact same on several bars. Ideas? http://www.sierrachart.com/image.php?Image=1573669092701.png Date Time Of Last Edit: 2019-11-15 04:03:15
[2019-11-15 04:02:57] |
This is explained here: Volume By Price Study: How Volume by Price is Calculated for Historical Daily and Higher Timeframe Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-11-15 18:41:35] |
Thank you!
