Date/Time: Mon, 03 Feb 2025 10:48:46 +0000
I am trying to open sierra on a laptop not used for a while while i am away
View Count: 622
[2019-11-13 10:19:58] |
User593438 - Posts: 2 |
message reads current service package does not support this option? I am pretty sure I have possiblility to run on 2 systems please advise |
[2019-11-13 21:14:08] |
The software on your computer is out of date for the Trading service you are using. You need to upgrade the software using these instructions: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
