Date/Time: Mon, 03 Feb 2025 12:56:53 +0000
Displaying Current Price Line on a Renko Chart
View Count: 621
[2019-11-12 09:03:11] |
User275592 - Posts: 97 |
Hi, i'm using Renko chart and i'd like to disoplay the current price line (with the study current price line) The study displays a line, but it sis not the current value It seems that the price displayed is part of the last renko brick Thank you for your help Renaud |
[2019-11-12 09:23:27] |
Ackin - Posts: 1865 |
Try this: In the study setup, change "Input Data" (In2) to "Renko Close" |
[2019-11-12 14:19:24] |
With the Current Price Line study, set the Use Last Trade Price from Current Quote Data Input to Yes.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-11-12 14:19:53
[2019-11-18 10:16:34] |
Thank you for your help I modified the Input to "Use Last Trade Price from Current Quote Data" to YES and it works ! SierraChart = Great Plateform with Great Support |
