Date/Time: Mon, 03 Feb 2025 12:54:44 +0000
New PC, how to transfer chartbooks? I setting up SC to trade my IBKR account through it
View Count: 742
[2019-11-12 07:08:26] |
brown555 - Posts: 35 |
I have all my chartbooks setup the way I want on my PC, then I bought a new PC that I want to dedicate to trading. I spent a lot of time setting up my charts the way I want, but when i copied the 2 .Cht files over to my new PC, the charts don't look the same, the indicators are giving incorrect data, and most of the price data is bad. Should I just start over setting up my charts, or is there a way to copy/transfer to my new PC?
[2019-11-12 14:17:03] |
Refer to help topic 15: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation the indicators are giving incorrect data, and most of the price data is bad. We need to understand this. Post an image of the chart following these instructions:https://www.sierrachart.com/index.php?page=PostingInformation.php#PostingAnImage We do not understand how price data can be "bad". Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-11-12 14:18:19
[2019-11-18 05:05:29] |
Here - this is how price data can be "bad". All softs charts show the last price to be -1 http://www.sierrachart.com/image.php?Image=1574053481868.png |
[2019-11-18 16:46:17] |
That -1 value is coming from Trader Workstation. The solution is to uncheck this option in the Chart Settings for the affected charts: https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#RealTimeUpdatingHistChart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-11-18 16:46:32
