Date/Time: Mon, 03 Feb 2025 10:05:34 +0000
Reset software
View Count: 526
[2019-11-12 03:40:22]
User574087 - Posts: 2
Hey Team,
in have a small issue with my your software.
When sierra chart will open, there is no more menu above the charts. Before i was able to have a quick access to switsch the time frame, lines and other tools. But i dont know how to reset that.
Can you help me out here or is it possible to reset the sierra?
Thanks and Greets
[2019-11-12 04:43:04]
Maybe you are referring to the Control Bar? If so, refer to:
Control Bar
