Date/Time: Thu, 19 Sep 2024 16:05:04 +0000
Compiling issue again???
View Count: 1249
[2013-12-21 11:18:02] |
test99 - Posts: 26 |
Trying to compile my old code using version 1063 latest GCC compiler. Code is in working condition, it was debugged and is being used presently as dll file. Is this the same issue as in this thread "Compiling cpp file started by ABeyer" posted on the message board? I am getting g++.exe application error in a popup window and a message below. -- Starting build of Custom Studies Source files: AdaptiveMAfilterTrading.cpp. -- 03:09:59 "C:\SierraChart\CPPCompiler\bin\g++.exe" "C:\SierraChart\ACS_Source\AdaptiveMAfilterTrading.cpp" -march=i686 -mtune=i686 -O2 -shared -static -static-libgcc -static-libstdc++ -s -fno-rtti -fno-exceptions -o "C:\SierraChart\Data\AdaptiveMAfilterTrading.dll" -- End of Build -- 03:10:02 Thanks for you help guys. |
[2013-12-22 05:57:57] |
We recommend reinstalling the compiler as explained here: http://www.sierrachart.com/index.php?l=doc/doc_CreatingDLLs.html#ReinstallingCPPCompiler If this does not help, we do not know what the problem is. The build log you have provided does not indicate a problem and we are not sure why you would get a pop-up application error message from the compiler program itself. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-12-25 00:17:47] |
Reinstalled GCC compiler as you advised. The same issue with crashing compiler exist. Please contact GCC developer if there is a known issue with running GCC compiler on Win 7. Thanks. Any other suggestions are appreciated. Merry Christmas. |
