Date/Time: Tue, 22 Sep 2026 08:02:15 +0000
Backtest/Replay - possible to use timer for flattening positions & cancel orders?
View Count: 1220
[2019-11-11 20:22:16]
Chad - Posts: 247
Per the title, is it possible in a back-testing environment for a 'timer' routine to flatten positions, cancel any open orders, and block any new orders, during a specific day-of-week and timeframe? I would regularly have more than one 'event' during the week to use a timer for, so having two session start/end times wouldn't suffice.
[2019-11-12 04:38:39]
Yes this is certainly possible. How is the trading system implemented?
[2019-11-12 17:13:47]
Chad - Posts: 247
The tentative plan is to handle all new order events in ACSIL, no Alert studies from Charts; timers configured using sc.IsDateTimeContainedInBarIndex. If you meant a different aspect in context of 'implementation', please clarify.
[2019-11-12 18:13:31]
This can certainly be done. You would want to examine the date-time in:
ACSIL Interface Members - Variables and Arrays: sc.BaseDateTimeIn[]
And then take the action that you need to.
An example of something related to this is in: /ACS_Source/TradingSystemBasedOnAlertCondition.cpp
This is in the Sierra Chart installation folder.
Have a look at how this variable is used: Input_AllowTradingOnlyDuringTimeRange
Date Time Of Last Edit: 2019-11-12 18:14:22
[2019-11-27 21:01:13]
User568537 - Posts: 21
Hi
I would like to do something similar but using the "Trading System Based on Alert Condition" study: i.e. go long only on Tuesday at a specific time and exit on Wednesday at another time. Is it possible?
[2019-12-03 06:11:18]
You can certainly modify the study to meet your requirements. Refer to:
How to Build an Advanced Custom Study from Source Code
Date Time Of Last Edit: 2019-12-03 06:11:28
