Date/Time: Mon, 03 Feb 2025 10:06:16 +0000
Standard Deviation Study
View Count: 842
[2019-11-11 12:07:48] |
User94740 - Posts: 333 |
I am trying to find a study similar to the attached pic. The pic is from the MT5 platform. It enables you to place the beginning and ending, but the result are straight lines. It would be appreciated to know if SC has something similar.
Date Time Of Last Edit: 2019-11-11 12:09:00
Std Dev Ex..JPG / V - Attached On 2019-11-11 12:07:06 UTC - Size: 20.01 KB - 430 views |
[2019-11-11 17:28:44] |
The only thing that comes close is the Parallel Lines drawing tool: Chart Drawing Tools: Parallel Lines Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
