Date/Time: Sun, 24 Nov 2024 23:10:29 +0000
Load chart at 100ms
View Count: 1235
[2013-12-21 09:01:27] |
batman_ - Posts: 190 |
SC (a) How do i set single chart to load faster at 100ms? (b) Can you modify number of row to load in spreadsheet trading system to minimum 2 rows (E3 and E4 only) instead of present at 10 rows? TQ |
[2013-12-21 09:09:47] |
1. This is not supported. This is planned for later. 2. This is not supported. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-12-21 13:28:21] |
User30668 - Posts: 108 |
This is very good news. It would save a lot of CPU load because, at least in my case, just very few charts in a chartbook need to be running very fast. All the others could be running much slower. I know that we can use different instances of SC (that's what I do) but in many cases we need to have several charts in the same chartbook / instance to share information (i.e. Study Overlays). So I am glad to learn that this improvement is planned for later. Please don't forget about it. Thank you SC Engineering. Date Time Of Last Edit: 2013-12-21 13:29:34
