Date/Time: Mon, 03 Feb 2025 10:14:35 +0000
Gap in historical data
View Count: 654
[2019-11-11 05:25:10] |
User87726 - Posts: 9 |
I've been looking at historical data for symbols TICK-YM AND TICK-NASDAQ and have come across a gap in the data for both symbols beginning 03-25-19 and ending 04-24-19. I've had no problem retrieving data for dates prior to or after the gap. I'm wondering if this is a technical issue or something uniquely related to my account/subscription. Thanks.
[2019-11-11 14:13:26] |
Follow the instructions here: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Retrying the Download When There is Data in the Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-11-11 16:34:08] |
Re-downloading the data file solved the problem. Thanks.
