Date/Time: Mon, 03 Feb 2025 07:54:51 +0000
Number Bars Style
View Count: 673
[2019-11-08 22:31:12]
User965825 - Posts: 15
could someone please help me with the number bars. I would like to have it like on these two files attached.
I´m trying for two hours now, but have no idea how to set them up. I would like to have the ask and bid with an x in between
and with the colored boxes with different shadow levels.
Thank you
imageNumberbars2.PNG / V - Attached On 2019-11-08 22:30:36 UTC - Size: 347.9 KB - 360 views
imageNumberbars.PNG / V - Attached On 2019-11-08 22:30:43 UTC - Size: 89.9 KB - 352 views
[2019-11-08 23:41:35]
cmet - Posts: 599
It's difficult to duplicate the background shading without knowing what it's based on.
From the low rez image you posted, it looks like it might be the Actual Bid/Ask Volume Difference.
Attached is a Chartbook that may be close to what you're looking for.
attachmentChartbook1.Cht - Attached On 2019-11-08 23:41:01 UTC - Size: 30.6 KB - 339 views
[2019-11-09 01:24:56]
Thank you pst. Helped me a lot. That´s what I was looking for. Your chartbook helped me also to understand the settings more.
