Date/Time: Sun, 24 Nov 2024 23:25:00 +0000
hyperlink between a date and time in a spreadsheet and the same date and time in a chart
View Count: 1271
[2013-12-21 05:13:36] |
4646ed - Posts: 230 |
Is it possible to set up a hyperlink between a date and time in a spreadsheet and the same date and time in a chart? If so, how do you recommend doing it? For example I click on the link in the spreadsheet and the chart opens/goes to that date and time.
[2013-12-23 07:41:23] |
The emphasis would be on the "going to" part of the question - if the chart were already open. Another good thing would be if you could just type in the date/time you want to go to directly on the chart, like you do with the instrument or the bar period, instead of using the go to dialogue box.
Date Time Of Last Edit: 2013-12-23 07:42:33
