Date/Time: Mon, 03 Feb 2025 07:57:34 +0000
Interactive brokers
View Count: 627
[2019-11-08 15:05:29] |
Dazzer - Posts: 8 |
Hi, I currently subscribe to your data. Is it possible to use your data but trade through my Interactive Brokers account. If so how is that setup. I know how to connect TWS but only if I disconnect your data.?
[2019-11-08 15:20:40] |
This is explained here: Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services (Integration with Trading Services) You should deactivate the Sierra Chart Exchange Data Feed renewal for this month. We can do that for you. And then next month activate the Denali Exchange data feed instead which is lower-cost and on a better network: Denali Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-11-08 15:21:50
