Date/Time: Mon, 03 Feb 2025 08:15:01 +0000
Issue with Processing of Linking Studies through Charts - Multiply Bars by -1 Specifically
View Count: 617
[2019-11-08 12:25:19]
User34124 - Posts: 279
A small niggle but occasionally when I employ that study, which has been saved as a collection, on one chart out off 100+, one or two random charts do not get affected. So it is particularly noticeable on the eye as one gets to the chart. Simply reclicking the study by reclicking the collection under Analysis does indeed fix the problem, so I wonder how this process works regarding processing? Is it likely this would skip due to the nature of that many charts linked? Is there anything I can do to slow this down to increase precision? CPU lag is not the culprit as under resource monitor the work is spread over 4/16 cores, total % is less than 10, and the time taken for study application is about 4sec.
