Date/Time: Mon, 03 Feb 2025 10:11:08 +0000
questions
View Count: 611
[2019-11-08 08:33:02] |
User389151 - Posts: 37 |
how to always reveal zone levels when drawing horizontal lines like this? see attached Also, how to create keyboard shortcut to buy/sell limit 2 ticks from current price(with attached bracket order)? Not liking using market order. Date Time Of Last Edit: 2019-11-08 08:37:27
Capture.JPG / V - Attached On 2019-11-08 08:37:10 UTC - Size: 23.35 KB - 255 views |
[2019-11-10 03:07:09] |
We assume you are asking how to always display the Price label on a Horizontal Line. You just need to setup the configuration to have that on and have that configuration selected when you draw the line. Refer to the following: Chart Drawing Tools: Drawing Tool Configuration Refer to the following for Custom Trading Keyboard Shortcuts: Basic Trading and the Trade Window: Custom Trading Keyboard Shortcuts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
