Date/Time: Mon, 03 Feb 2025 07:49:31 +0000
MYM
View Count: 643
[2019-11-07 21:44:43] |
User317484 - Posts: 15 |
i am running cqg on your sytem i do not see the symbol for MYM ( micro dow futures) by the CME thank you steven leon |
[2019-11-08 01:45:28] |
It is definitely listed. It starts with F.US.MYM.
[2019-11-08 01:45:52] |
It's listed under Futures - CBOT. It is definitely listed. It starts with F.US.MYM. You can also use the search feature to find symbols. Refer to the following: File Menu: Searching for Available Symbols Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
