Date/Time: Mon, 03 Feb 2025 07:51:25 +0000
Depth levels on Sierrachart exchange data feed
View Count: 667
[2019-11-07 13:00:41]
User708333 - Posts: 18
On SC's new data feed, How many levels of depth are there for ES and CL currently?
[2019-11-07 13:27:45]
Up to 500 levels and it is adjustable by each user.
Date Time Of Last Edit: 2019-11-07 13:27:56
[2019-11-07 13:43:30]
Thats great, I am with AMP futures and CQG data currently and am thinking of switching, will there be any issues using this data feed with AMP?
[2019-11-08 01:27:10]
There are no issues using our data feed with AMP. If you are only looking to get data from the CME, then refer to the following:
Denali Exchange Data Feed
We also recommend using the Sierra Chart Order Routing service that also works with AMP. You will find the information here:
Sierra Chart / Trading Technologies Futures Order Routing Service
