Date/Time: Mon, 03 Feb 2025 08:18:02 +0000
Lower case Chart Header Bug
View Count: 551
[2019-11-07 10:23:20]
User34124 - Posts: 279
Global Settings > Chart Header is displaying Symbol and Bar period only.
Once I inputted two symbol names as following via Chart Settings (F5): AUDjpy and AUDusd.
Now anywhere I go within SC, new chartbooks or anything, if I try to quick access these two symbols, by typing audusd or AUDUSD into the chart, and pressing enter, they always come up as above. I have checked all open charts in other chartbooks and made sure that they are all saved as upper case, and then resaving and restarting chartbooks. No joy. Somewhere in the cache they are logged as the old versions and SC keeps fetching it?
[2019-11-07 19:22:14]
There is no bug here. You created this problem by using the different letter case. You need to correct the case of the file name:
Chart Data and Chart Data Files: Correcting Letter Case Of Symbols
