Date/Time: Sat, 03 Oct 2026 07:36:30 +0000
changes to bid ask diff bars ?
View Count: 1067
| [2019-11-07 01:01:22] |
| zippyzip - Posts: 310 |
was there updates to this cause they look very different on the newer versions , you can see in picture that there is a void at the zero line , thanks
Private File |
| [2019-11-12 05:03:14] |
It has been more than 60 days since that study was worked on (Bid and Ask Depth Bars). Also, these kinds of screenshots have no context. You need to post an image of the chart following these instructions here: Support Board Posting Information: Attaching or Posting a Screenshot/Image (Optional) And then you need to tell us the settings you are using for that study and explain all of the calculations using the market depth data and explain why there is a problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-11-15 05:38:57
| [2019-11-15 02:29:39] |
ok but there are not setting for this study , nor is it depth data so i dont understand that part above , its simply bid vs ask difference bars and you can see the spacing from the zero line is very erratic
Attachment Deleted. Private File Private File |
| [2019-11-20 02:32:24] |
