Date/Time: Mon, 06 May 2024 02:47:07 +0000
Brokers
View Count: 620
[2019-11-06 16:23:35] |
Tecomed - Posts: 6 |
Hi, Do you support TT connection to RJO Brian - RJO Futures? Thanks |
[2019-11-06 16:32:44] |
Yes technically this is possible. No restrictions from our side. But this is something that RJ O'Brien would have to also be in agreement with and we do not know what the pricing would be from them.
