Date/Time: Wed, 16 Sep 2026 04:55:30 +0000
Adding Denali data feed
View Count: 1042
| [2019-11-05 18:10:46] |
| User286466 - Posts: 12 |
Hello, I currently have an account with TransAct and I am using their data feed TransAct WS service. I use TransAct AT software on a laptop for placing trades all orders go thru my laptop. I would like to try the Denali data feed. I was planning on downloading another copy of Sierra Chart in a different folder for use with Denali. I assume I need "Denali Exchange Data Feed for other services: 25 USD/month" I also assume I can order "Full CME Group (CME, CBOT, COMEX, NYMEX) for nonprofessional Trading accounts" For $3.25 per month. Or do I need "Full CME Group (CME, CBOT, COMEX, NYMEX) with Market Depth for nonprofessional Trading accounts" For $15.75 per month? Are my assumptions correct? Anything else I should know before setting up Denali? thanks, |
| [2019-11-05 19:55:41] |
Or do I need "Full CME Group (CME, CBOT, COMEX, NYMEX) with Market Depth for nonprofessional Trading accounts" For $15.75 per month? Which one of these you select is completely up to you. The only difference is the Market Depth data. If you need/want the Market Depth, then you want to use the "Full CME Group (CME, CBOT, COMEX, NYMEX) with Market Depth for nonprofessional Trading accounts" Are my assumptions correct?
Yes, apart from the above.Also, be aware that you will need to connect to your trading account at TransAct in order to qualify for the lower-priced exchange fees. Refer to the following: Real-Time Exchange Data Feeds Available From Sierra Chart: Connecting Only Once a Month to Trading Account to Support CME Group Exchange Fees Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
