Date/Time: Mon, 03 Feb 2025 06:50:35 +0000
Realtime data but does not update
View Count: 605
[2019-11-05 14:58:47] |
maxpi - Posts: 181 |
I'm on the Danali exchange data looking at ESZ19. My Data/Trade Service setting is to SC Data-All Services. If I disconnect/connect the Data/Trade Service [ctrl+F11 then F11] my data will update to the latest quote. If I then just leave it connected my chart does not update.
[2019-11-05 15:08:04] |
What futures trading/brokerage service do you use? For the reason why we ask this question, refer to: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges (Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
