Date/Time: Mon, 03 Feb 2025 07:07:02 +0000
Split intraday TPO VBP
View Count: 1121
[2019-11-05 03:25:27]
User232042 - Posts: 35
Hello, I've been using Sierra charts for a bit and have thoroughly enjoyed it. I've been struggling with the idea to switch to Window Trader recently because their software allows the volume for each TPO time period to be displayed separately. For example, I can split every TPO sub period into A column, B column, C column, ect. and have the VolumeByPrice strictly for each 30-min period next to it. For example, the VBP for A period, then separately - the VBP for B period, ect. If you're able to add this into Sierra Charts that would be amazing, unfortunately, I may have to switch trading platforms if unable. I know this is a key element for many other traders that have made the switch as well. Thanks for your time.
[2019-11-05 13:13:23]
This is already supported. Simply open a chart and set the chart bars to 30 minutes per bar and use the Volume by Price study configured as follows:
Volume By Price Study
You can vary the configuration as you need.
