Date/Time: Mon, 03 Feb 2025 07:11:09 +0000
[User Discussion] - Price Change on Quote Board
View Count: 829
[2019-11-04 16:14:27] |
User135370 - Posts: 162 |
Hi Is there a way I can highlight the price change on the Quote board. The daily change is coloured red for down and green. Is there a way I can do that with the last price to see visually if it’s ticking up or down? |
[2019-11-05 10:08:23] |
User495158 - Posts: 108 |
As far as I know, not directly. But you can use "trade direction" in settings/ set fields. It would display + or - sign on price changes, which would also change in color. The other way to do it would be to use quote spreadsheet. I think there you have the option to see color changes when price changes. Date Time Of Last Edit: 2019-11-05 10:08:56
[2019-11-05 10:14:58] |
If Price Direction shows me a + or a - then that should suffice Thanks you Will try it |
