Date/Time: Sun, 05 May 2024 23:20:51 +0000
why can't I find anything on options??
View Count: 713
[2019-11-04 15:45:48] |
User849502 - Posts: 299 |
thank you for my reply, and really I did think to look in the 'find symbol' area, but as you will see by enclosed photo of my 'find symbol' window I don't futures options listed. I even scrolled thru all the futures listing thinking it might be at the end. It was not. What next boss!!! Thank you so much. Karen
[2019-11-06 03:51:39] |
We apologize for the delay. We need to prepare screenshot related to this . This will be done tomorrow.
[2019-11-06 04:26:59] |
seandunaway - Posts: 213 |
Attached.
Date Time Of Last Edit: 2019-11-06 04:50:58
sc options2.png / V - Attached On 2019-11-06 04:50:53 UTC - Size: 554.21 KB - 413 views |
[2019-11-06 20:00:17] |
In regards to post #3, it just happens to be by chance that the instructions you gave, were appropriate for post #1. There are two different methods of accessing options. In the case of the SC Futures order routing service it is identical to CQG.
