Date/Time: Mon, 03 Feb 2025 07:11:48 +0000
[User Discussion] - Numbers Study with LSE Intraday Day (London Stocks)
View Count: 614
[2019-11-04 15:23:06] |
mbilyanov - Posts: 62 |
Hi, I'm new to SierraCharts but have been reading the documentations for a while. I'm aware about the IB issues etc. and other data problems related to London stocks. I'm subscribed to all of the data packages (real-time/historic) that come for the new subscribers. What is the best solution to get the Numbers (Bid/Ask) Study to work with LSE stocks? 1) If using IB is ok? I'm able to pull-in intraday stocks tick data for LSE through IB following the documentation (ex: For AstraZeneca AZN-STN-SMART). However, usually the Number Study boxes and visuals are too compressed and hard to read. I'm reading the Numbers Study help right now and there is a section that explains how to fix the UI readability issues. However, is IB the way to go? If 'yes', do I need to tweak things like 'Minimum Tick Size' etc? I'm also getting some backfill issues, the chart is fragmented going back in time. 2) If Sierra's Real Time Data is also providing LSE stocks data that is capable of running the Numbers and other Bid/Ask studies, then I should be accessing those through the SC compatible symbol (ex: For AstraZeneca AZN.LS) and I don't need my IB data? 3) Many posts related to LSE mention TeleTrader, do we still need that? ... or is Sierra's data feed or IB's data feed is sufficient? Thanks, Milen |
