Date/Time: Mon, 03 Feb 2025 07:18:36 +0000
how to clear cumulative profit and lost
View Count: 1060
[2019-11-04 09:29:18] |
User642012 - Posts: 58 |
hi i look at the spreadsheet system for trading. the cumulative profit and lost is always there even i started a new day i trled to clear trade activity log but it still shows the previous p and l . which makes ne unable to keep track of the current daily p/L in the spreadsheet |
[2019-11-04 13:05:17] |
There is nothing you need to clear. Instead refer to: Trade Activity Log: Understanding and Setting the Start Date-Time for a Trades List And if you want just the Daily Profit/Loss that is what you should be referencing and it is also outputted to one of the cells in the J column in the Sheet. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-11-04 13:05:39
[2019-11-04 13:19:03] |
Hi It’s J11 , it always shows a p/L a few days ago , and never reset to zero when A new day started |
[2019-11-04 20:59:05] |
You need to use the Daily Profit/Loss cell instead. It is there as well. Refer to: Spreadsheet Systems, Alerts and Automated Trading Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-11-04 21:00:08
