Date/Time: Tue, 04 Nov 2025 14:57:42 +0000
[User Discussion] - OSX & Parallels Shortcut problems
View Count: 2686
|   [2013-04-12 03:26:03]     |
| dem_z - Posts: 14 |
                Is it possible to remap shortcuts?  The F-key shortcuts on Sierra are the most useful for me, but they conflict with the bindings on OSX --- Which have them as iTunes controls.  I try holding down the "Function" key with no-avail.  |
|   [2013-04-12 06:08:36]     |
                See: http://www.sierrachart.com/index.php?l=doc/doc_GlobalSettingsMenu.html#CustomizeKeyboardShortcuts Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing  |
