Date/Time: Mon, 03 Feb 2025 10:55:18 +0000
[Programming Help] - Volume At Price Threshold Alert V2
View Count: 2209
[2019-11-03 20:50:16]
Dorian - Posts: 61
Hello, I would like to make the Ask Volume Bid Volume (Diagonal) Ratio display a line here it is greater than 500% but also that the volume is greater than 55 to display the line (AskVol BidVol Difference Diagonal) (Delta Diagonal Vol >+55 or Delta Diagonal Vol <-55). Volume Threshold is off when I use the Ask Volume Bid Volume (Diagonal) Ratio. The function works if I use the Diagonal Ask Volume Bid Volume Difference but the percentage will be disabled. It would be necessary for the two to work would be absolute perfection and one could create the Edge Zones as MarketDelta invented it.
Best Regards,
Dorian
Date Time Of Last Edit: 2019-11-03 22:31:59
[2019-11-04 16:37:04]
User215984 - Posts: 24
+1
I asked for this about 6 months ago. This would be a great enhancement!!!
[2019-11-06 03:53:23]
That study is easily modified to meet your requirements. Refer to:
How to Build an Advanced Custom Study from Source Code
[2019-11-06 15:25:37]
Ackin - Posts: 1865
Dorianstoll )
The diagonal imbalance ratio is free in our forum + similar studies with other parameters. Also study Diagonal delta difference. Just registration and you got it.
I can merge it and it will be what you need. It will be possible to download the requested modification tomorrow.
Ackin's indicators (SCH users requests for studies) - Update list | Post: 193747
Date Time Of Last Edit: 2019-11-06 15:26:45
[2019-11-06 16:19:08]
Ackin,
Great news, I didn't want to learn how to program!
Thanks!
[2019-11-14 11:36:23]
Dorian - Posts: 61
Thank you for your reply.
I added the code line of else if (ComparisonMethodIndex == 5)//Ask Volume Bid Volume Diagonal Difference
The Volume Threshold is working now. But it does not take into account the Percentage Threshold when I put a number other than 0.
See attached images.
imageadd.png / V - Attached On 2019-11-14 11:36:02 UTC - Size: 118.17 KB - 482 views
imageproblem.png / V - Attached On 2019-11-14 11:36:16 UTC - Size: 137.27 KB - 532 views
