Date/Time: Mon, 03 Feb 2025 06:57:16 +0000
Offset symbol price
View Count: 577
[2019-11-03 20:46:55] |
samuelson - Posts: 9 |
My brokers price and the Seirra chart price are sometimes off by a few pips on some symbols. How can I offset the price on a symbol so that it matches my broker?
[2019-11-03 23:42:12] |
Tell us one of the symbols you are referring to. And who is the broker?
[2019-11-04 00:51:50] |
It doesn’t matter, I would just like to offset the price.
[2019-11-04 03:16:41] |
Refer to: Using the Basic Arithmetic Studies Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
