Date/Time: Mon, 03 Feb 2025 06:54:37 +0000
Advanced order types in simulation?
View Count: 536
[2019-11-03 12:10:32] |
BenjFlame - Posts: 335 |
Hi, Are advances order types such as « Triggered Limit with Chase » available and working in simulation mode? |
[2019-11-03 15:09:58] |
Yes this is all fully supported.
