Date/Time: Mon, 03 Feb 2025 04:52:54 +0000
Intraday vs Historical Volume
View Count: 838
[2019-11-02 18:36:33] |
User49270 - Posts: 48 |
Hi, I'm trying to construct a daily stock chart using intraday session times for bid ask volume comparison. No matter which session times I try the end of day daily volume doesn't compare to the historical daily volume which has the correct volume.
[2019-11-03 01:48:18] |
This is explained in help topic 43: Differences With Data and Chart Bars Between Services / Connections / Chart Types Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
