Date/Time: Mon, 03 Feb 2025 05:05:00 +0000
Socket closed
View Count: 757
[2019-11-01 16:07:17]
Rene Velazquez - Posts: 9
I get a message for socket closed by remote side, my chart is not updating. Any idea why?
Rene
[2019-11-01 16:07:37]
Sierra Chart - Max - Posts: 5780
If you are having a problem doing something with Sierra Chart, then in many cases the Message Log will be helpful.
Copy and paste the *entire* copy of the Message Log into your email message or Support Board message according to the instructions below. Sending some of the lines is not helpful. The entire Message Log is needed. The Message Log does not contain any private information.
1. If the Sierra Chart Message Log is not already open, then select "Window >> Message Log" on the menu to open it. If you still do not see the log after selecting this command, then select "Window >> Reset Windows". The Message Log will be displayed in this case. If not, then select "Window >> Message Log" again.
2. Press the "Copy Log" button or use "Edit >> Copy Entire Log" on the menu on the Message Log window. This will automatically copy the Message Log to the system clipboard. Do not use the "Send for Analysis". Otherwise, the log will not be seen.
3. Move your Pointer to the message area either in the email message, Support Board or Account Support Ticket.
4. Right-click your Pointer. Select "Paste" on the menu to paste it into the message area.
Sierra Chart Support
[2019-11-01 16:20:32]
Reading Internal Order ID file. | 2019-11-01 08:03:29.980
Reading Trade Orders file. | 2019-11-01 08:03:30.243
Reading Trade Positions file. | 2019-11-01 08:03:30.456
Reading Account Balance file. | 2019-11-01 08:03:31.056
UDPListener (1496). Port 22904 | Listening on UDP port 22904. | 2019-11-01 08:03:31.339
Software version: 1987 32-bit | 2019-11-01 08:03:31.339
Usage end date: 2019-11-23 | 2019-11-01 08:03:31.339
Enabled for: Sierra Chart Historical Data Service. | 2019-11-01 08:03:31.339
Allow Support for Sierra Chart Data Feeds is enabled. | 2019-11-01 08:03:31.339
Current selected Data/Trading service: SC Futures Order Routing/Data | 2019-11-01 08:03:31.339
Custom symbol settings values: disabled | 2019-11-01 08:03:31.339
Chart Update Interval: 500 | 2019-11-01 08:03:31.339
Intraday Data Storage Time Unit: 1 | 2019-11-01 08:03:31.339
Time Zone: -05:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2019-11-01 08:03:31.339
2019-11-01 06:03:31 Local computer time | 2019-11-01 08:03:31.339
2019-11-01 13:03:31 Local computer time in UTC | 2019-11-01 08:03:31.339
2019-11-01 08:03:31 Local computer time in SC Time Zone | 2019-11-01 08:03:31.339
2019-11-01 13:03:28 Server time in UTC | 2019-11-01 08:03:31.339
Local computer UTC time and Server UTC time difference: 1 seconds. | 2019-11-01 08:03:31.339
Program path: C:\SierraChart\ | 2019-11-01 08:03:31.339
Data Files path: C:\SierraChart\Data\ | 2019-11-01 08:03:31.339
OS Version Number: 10.0 | 2019-11-01 08:03:31.340
Locale Setting: C | 2019-11-01 08:03:31.340
DLLs: UserContributedStudies.dll, UserContributedStudies_64.dll | 2019-11-01 08:03:31.346
Created the DTC Protocol server. | 2019-11-01 08:03:31.373
DTC Protocol Server listening on port 11099. | 2019-11-01 08:03:31.374
Created the DTC Protocol historical data server. | 2019-11-01 08:03:31.374
HD Server Manager | Listening on port 11098 | 2019-11-01 08:03:31.376
Checking for new symbol settings. Requested symbol settings MD5 for service code sc_futures.dtc.trading. Request ID: 1. | 2019-11-01 08:03:31.376
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2019-11-01 08:03:31.425
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2019-11-01 08:03:31.622
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2019-11-01 08:03:31.622
Received 5 login tokens. | 2019-11-01 08:03:32.129
Symbol settings MD5 received. Request ID: 1. | 2019-11-01 08:03:32.336
Symbol settings are up-to-date for sc_futures.dtc.trading. | 2019-11-01 08:03:32.336
Files to Open on Start up | Opening file: FUTURES OIL CL.Cht | 2019-11-01 08:03:35.242
6SM9-CME 50 Trades #7 | Reloading chart. | 2019-11-01 08:03:35.799
CLX9-NYMEX 1597 Trades #2 | Reloading chart. | 2019-11-01 08:03:39.601
CLX9-NYMEX 2584 Trades #13 | Reloading chart. | 2019-11-01 08:03:41.682
CLX9-NYMEX 4181 Trades #8 | Reloading chart. | 2019-11-01 08:03:42.019
CLX9-NYMEX 6765 Trades #1 | Reloading chart. | 2019-11-01 08:03:42.158
CLX9-NYMEX 10946 Trades #4 | Reloading chart. | 2019-11-01 08:03:42.307
CLX9-NYMEX 10946 Volume #5 | Reloading chart. | 2019-11-01 08:03:42.367
CLX9-NYMEX 1597 Volume #10 | Reloading chart. | 2019-11-01 08:03:42.423
CLX9-NYMEX 2584 Volume #9 | Reloading chart. | 2019-11-01 08:03:42.486
CLX9-NYMEX 4181 Volume #6 | Reloading chart. | 2019-11-01 08:03:42.539
CLX9-NYMEX 6765 Volume #3 | Reloading chart. | 2019-11-01 08:03:42.609
Files to Open on Start up | Opening file: CLX.Cht | 2019-11-01 08:03:42.926
CLZ19_FUT_NYMEX 5 Min #12 | Reloading chart. | 2019-11-01 08:03:43.849
CLZ19_FUT_NYMEX 1597 Trades #1 | Reloading chart. | 2019-11-01 08:03:44.909
CLZ19_FUT_NYMEX 2584 Trades #2 | Reloading chart. | 2019-11-01 08:03:46.223
CLZ19_FUT_NYMEX 4181 Trades #3 | Reloading chart. | 2019-11-01 08:03:46.488
CLZ19_FUT_NYMEX 6765 Trades #4 | Reloading chart. | 2019-11-01 08:03:46.763
CLZ19_FUT_NYMEX 10976 Trades #5 | Reloading chart. | 2019-11-01 08:03:47.023
CLZ19_FUT_NYMEX 10976 Volume #6 | Reloading chart. | 2019-11-01 08:03:47.370
CLZ19_FUT_NYMEX 1597 Volume #8 | Reloading chart. | 2019-11-01 08:03:47.660
CLZ19_FUT_NYMEX 2584 Volume #9 | Reloading chart. | 2019-11-01 08:03:47.998
CLZ19_FUT_NYMEX 4181 Volume #10 | Reloading chart. | 2019-11-01 08:03:48.295
CLZ19_FUT_NYMEX 6765 Volume #7 | Reloading chart. | 2019-11-01 08:03:48.630
QMX19_FUT_NYMEX 50 Trades #13 | Reloading chart. | 2019-11-01 08:03:49.045
Files to Open on Start up | Opening file: CLZ.Cht | 2019-11-01 08:03:49.145
CLZ19_FUT_NYMEX 5 Min #12 | Reloading chart. | 2019-11-01 08:03:50.002
QMZ19_FUT_NYMEX 50 Trades #13 | Reloading chart. | 2019-11-01 08:03:50.287
CLZ19_FUT_NYMEX 1597 Trades #1 | Reloading chart. | 2019-11-01 08:03:50.946
+ Loading market depth data. | 2019-11-01 08:03:51.129
CLZ19_FUT_NYMEX 10976 Volume #6 | Reloading chart. | 2019-11-01 08:03:51.279
CLZ19_FUT_NYMEX 2584 Trades #2 | Reloading chart. | 2019-11-01 08:03:51.602
CLZ19_FUT_NYMEX 4181 Trades #3 | Reloading chart. | 2019-11-01 08:03:51.929
CLZ19_FUT_NYMEX 6765 Trades #4 | Reloading chart. | 2019-11-01 08:03:52.262
Loaded depth data records for CLZ19_FUT_NYMEX 2019-10-29 from 2019-10-28 23:26:09 to 2019-10-29 18:59:57. | 2019-11-01 08:03:53.288
CLZ19_FUT_NYMEX 10976 Trades #5 | Reloading chart. | 2019-11-01 08:03:55.405
CLZ19_FUT_NYMEX 1597 Volume #8 | Reloading chart. | 2019-11-01 08:03:55.749
CLZ19_FUT_NYMEX 2584 Volume #9 | Reloading chart. | 2019-11-01 08:03:56.047
CLZ19_FUT_NYMEX 4181 Volume #10 | Reloading chart. | 2019-11-01 08:03:56.436
CLZ19_FUT_NYMEX 6765 Volume #7 | Reloading chart. | 2019-11-01 08:03:56.795
6SM9-CME 50 Trades #7 | StartDateTimeForLoadingOrderFills: 2019-05-19 17:00:00 | 2019-11-01 08:03:57.084
CLX9-NYMEX 1597 Trades #2 | StartDateTimeForLoadingOrderFills: 2019-08-19 17:00:00 | 2019-11-01 08:03:57.111
CLX9-NYMEX 2584 Trades #13 | StartDateTimeForLoadingOrderFills: 2019-07-21 17:00:00 | 2019-11-01 08:03:57.114
CLX9-NYMEX 4181 Trades #8 | StartDateTimeForLoadingOrderFills: 2019-07-21 17:00:00 | 2019-11-01 08:03:57.469
CLX9-NYMEX 10946 Trades #4 | StartDateTimeForLoadingOrderFills: 2019-07-21 17:00:00 | 2019-11-01 08:03:57.590
CLX9-NYMEX 10946 Volume #5 | StartDateTimeForLoadingOrderFills: 2019-07-21 17:00:00 | 2019-11-01 08:03:57.604
Loaded depth data records for CLZ19_FUT_NYMEX 2019-10-30 from 2019-10-29 19:00:00 to 2019-10-30 18:59:59. | 2019-11-01 08:03:57.612
CLZ19_FUT_NYMEX 5 Min #12 | StartDateTimeForLoadingOrderFills: 2019-10-31 17:00:00 | 2019-11-01 08:03:57.621
CLZ19_FUT_NYMEX 1597 Trades #1 | StartDateTimeForLoadingOrderFills: 2019-10-31 17:00:00 | 2019-11-01 08:03:57.707
CLZ19_FUT_NYMEX 2584 Trades #2 | StartDateTimeForLoadingOrderFills: 2019-10-31 17:00:00 | 2019-11-01 08:03:57.770
CLZ19_FUT_NYMEX 4181 Trades #3 | StartDateTimeForLoadingOrderFills: 2019-10-31 17:00:00 | 2019-11-01 08:03:57.777
CLZ19_FUT_NYMEX 6765 Trades #4 | StartDateTimeForLoadingOrderFills: 2019-10-31 17:00:00 | 2019-11-01 08:03:57.781
CLZ19_FUT_NYMEX 10976 Trades #5 | StartDateTimeForLoadingOrderFills: 2019-10-31 17:00:00 | 2019-11-01 08:03:57.805
CLZ19_FUT_NYMEX 10976 Volume #6 | StartDateTimeForLoadingOrderFills: 2019-10-31 17:00:00 | 2019-11-01 08:03:57.808
CLZ19_FUT_NYMEX 1597 Volume #8 | StartDateTimeForLoadingOrderFills: 2019-10-31 17:00:00 | 2019-11-01 08:03:57.814
CLZ19_FUT_NYMEX 2584 Volume #9 | StartDateTimeForLoadingOrderFills: 2019-10-31 17:00:00 | 2019-11-01 08:03:57.834
CLZ19_FUT_NYMEX 4181 Volume #10 | StartDateTimeForLoadingOrderFills: 2019-10-31 17:00:00 | 2019-11-01 08:03:57.841
CLZ19_FUT_NYMEX 6765 Volume #7 | StartDateTimeForLoadingOrderFills: 2019-10-31 17:00:00 | 2019-11-01 08:03:57.847
QMX19_FUT_NYMEX 50 Trades #13 | StartDateTimeForLoadingOrderFills: 2019-10-20 17:00:00 | 2019-11-01 08:03:57.852
CLZ19_FUT_NYMEX 5 Min #12 | StartDateTimeForLoadingOrderFills: 2019-10-31 17:00:00 | 2019-11-01 08:03:57.875
QMZ19_FUT_NYMEX 50 Trades #13 | StartDateTimeForLoadingOrderFills: 2019-10-31 23:00:00 | 2019-11-01 08:03:57.920
CLZ19_FUT_NYMEX 10976 Volume #6 | StartDateTimeForLoadingOrderFills: 2019-10-31 17:00:00 | 2019-11-01 08:03:57.947
CLZ19_FUT_NYMEX 2584 Trades #2 | StartDateTimeForLoadingOrderFills: 2019-10-31 17:00:00 | 2019-11-01 08:03:57.994
CLZ19_FUT_NYMEX 4181 Trades #3 | StartDateTimeForLoadingOrderFills: 2019-10-31 17:00:00 | 2019-11-01 08:03:58.059
CLZ19_FUT_NYMEX 6765 Trades #4 | StartDateTimeForLoadingOrderFills: 2019-10-31 17:00:00 | 2019-11-01 08:03:58.101
CLZ19_FUT_NYMEX 10976 Trades #5 | StartDateTimeForLoadingOrderFills: 2019-10-31 17:00:00 | 2019-11-01 08:03:58.135
CLZ19_FUT_NYMEX 1597 Volume #8 | StartDateTimeForLoadingOrderFills: 2019-10-31 17:00:00 | 2019-11-01 08:03:58.163
CLZ19_FUT_NYMEX 2584 Volume #9 | StartDateTimeForLoadingOrderFills: 2019-10-31 17:00:00 | 2019-11-01 08:03:58.244
CLZ19_FUT_NYMEX 4181 Volume #10 | StartDateTimeForLoadingOrderFills: 2019-10-31 17:00:00 | 2019-11-01 08:03:58.298
CLZ19_FUT_NYMEX 6765 Volume #7 | StartDateTimeForLoadingOrderFills: 2019-10-31 17:00:00 | 2019-11-01 08:03:58.334
Loaded depth data records for CLZ19_FUT_NYMEX 2019-10-31 from 2019-10-30 19:00:00 to 2019-10-31 18:59:59. | 2019-11-01 08:03:59.549
Loaded depth data records for CLZ19_FUT_NYMEX 2019-11-01 from 2019-10-31 19:00:00 to 2019-10-31 19:02:03. | 2019-11-01 08:03:59.598
CLZ19_FUT_NYMEX 1597 Trades #1 | StartDateTimeForLoadingOrderFills: 2019-10-31 17:00:00 | 2019-11-01 08:03:59.600
Market Depth Historical Graph | Current service package does not support this function. Select 'Help >> Account Control Panel' to change your package. | 2019-11-01 08:03:59.607 *
Market Depth Historical Graph | Current service package does not support this function. Select 'Help >> Account Control Panel' to change your package. | 2019-11-01 08:03:59.648 *
Starting DelayedDownloadMonitoringTimer | 2019-11-01 08:04:00.163
Starting HDTimeoutTimer | 2019-11-01 08:04:00.163
Added Intraday data request for CLZ19_FUT_NYMEX to the queue. | 2019-11-01 08:04:00.163
Intraday data recording state for symbol CLZ19_FUT_NYMEX is set to download 'Pending'. | 2019-11-01 08:04:00.163
Triggering next historical data download in queue. | 2019-11-01 08:04:00.163
HD Request # 2 | Downloading Intraday chart data for CLZ19_FUT_NYMEX to the file CLZ19_FUT_NYMEX.scid. Service: nymex | 2019-11-01 08:04:00.165
HD Request # 2 | Download start date-time: 2019-11-01 07:47:09.000 | 2019-11-01 08:04:00.165
HD Request # 2 | Using server: exchangehistdata2.sierracharts.com port 10150 | 2019-11-01 08:04:00.165
Socket (1) | Creating socket. | 2019-11-01 08:04:00.270
Socket (1) | Connecting to IP: 8.18.161.133. | 2019-11-01 08:04:00.270
Added Intraday data request for QMX19_FUT_NYMEX to the queue. | 2019-11-01 08:04:00.407
Intraday data recording state for symbol QMX19_FUT_NYMEX is set to download 'Pending'. | 2019-11-01 08:04:00.407
Triggering next historical data download in queue. | 2019-11-01 08:04:00.407
Added Intraday data request for QMZ19_FUT_NYMEX to the queue. | 2019-11-01 08:04:00.428
Intraday data recording state for symbol QMZ19_FUT_NYMEX is set to download 'Pending'. | 2019-11-01 08:04:00.428
Triggering next historical data download in queue. | 2019-11-01 08:04:00.428
Market Depth Historical Graph | Current service package does not support this function. Select 'Help >> Account Control Panel' to change your package. | 2019-11-01 08:04:00.438 *
HD Request # 2 | Setting DTC encoding to Binary VLS | 2019-11-01 08:04:00.487
HD Request # 2 | Sending historical data logon request message. | 2019-11-01 08:04:00.487
HD Request # 2 | Requesting Intraday data. Start date-time: 2019-11-01 07:47:09. Record interval: 1. Symbol: CLZ19 | 2019-11-01 08:04:00.589
SC Futures Order Routing/Data | Connecting to the server futurestrading2.sierracharts.com. Port 11098 | 2019-11-01 08:04:00.651
HD Request # 2 | Decompressing data. | 2019-11-01 08:04:00.693
HD Request # 2 | Receiving Intraday data for CLZ19_FUT_NYMEX starting at 2019-11-01 07:47:09 | 2019-11-01 08:04:00.694
HD Request # 2 | Timestamp of first Intraday data file record written: 2019-11-01 07:47:09 | 2019-11-01 08:04:00.695
Socket (1) | Shutdown started. Waiting for graceful close. | 2019-11-01 08:04:00.695
HD Request # 2 | Historical data for CLZ19_FUT_NYMEX is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2019-11-01 08:04:00.700
Historical data download thread signaled to stop. | 2019-11-01 08:04:00.701
HD Request # 2 | Received 311 records from 2019-11-01 07:47:09.000 to 2019-11-01 07:54:01.000 (6.9 minutes) and wrote 311 records for CLZ19_FUT_NYMEX | 2019-11-01 08:04:00.701
HD Request # 2 | Completion time: 0s | 2019-11-01 08:04:00.706
HD Request # 2 | Intraday data download complete for CLZ19_FUT_NYMEX. Unique request ID: 1 | 2019-11-01 08:04:00.706
Removed historical data download ID 1 | 2019-11-01 08:04:00.706
Triggering next historical data download in queue. | 2019-11-01 08:04:00.706
HD Request # 3 | Downloading Intraday chart data for QMX19_FUT_NYMEX to the file QMX19_FUT_NYMEX.scid. Service: nymex | 2019-11-01 08:04:00.706
HD Request # 3 | Download start date-time: 2019-10-21 13:29:49.000 | 2019-11-01 08:04:00.707
HD Request # 3 | Using server: exchangehistdata1.sierracharts.com port 10149 | 2019-11-01 08:04:00.707
DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2019-11-01 08:04:00.715
DTC Client socket (2) | Connecting to IP: 208.185.224.129. | 2019-11-01 08:04:00.715
Socket (1) | Socket gracefully closed by remote side. | 2019-11-01 08:04:00.800
Socket (1) | Closed. | 2019-11-01 08:04:00.800
Socket (3) | Creating socket. | 2019-11-01 08:04:00.813
Socket (3) | Connecting to IP: 8.18.161.135. | 2019-11-01 08:04:00.813
SC Futures Order Routing/Data | Connected to server. | 2019-11-01 08:04:00.822
SC Futures Order Routing/Data | Starting socket receive thread. | 2019-11-01 08:04:00.822
SC Futures Order Routing/Data | Sending encoding request to server: Binary VLS | 2019-11-01 08:04:00.822
HD Request # 3 | Setting DTC encoding to Binary VLS | 2019-11-01 08:04:01.026
HD Request # 3 | Sending historical data logon request message. | 2019-11-01 08:04:01.026
HD Request # 3 | Requesting Intraday data. Start date-time: 2019-10-21 13:29:49. Record interval: 1. Symbol: QMX19 | 2019-11-01 08:04:01.131
SC Futures Order Routing/Data | Setting DTC encoding to Binary VLS | 2019-11-01 08:04:01.175
SC Futures Order Routing/Data | Sending logon request message. | 2019-11-01 08:04:01.175
SC Futures Order Routing/Data | Received logon response. | 2019-11-01 08:04:01.300
SC Futures Order Routing/Data | Server Name: SC DTC Server. | 2019-11-01 08:04:01.300
SC Futures Order Routing/Data | Server protocol version: 8. Client protocol version: 8 | 2019-11-01 08:04:01.300
SC Futures Order Routing/Data | Successfully connected. Connected to SC DTC Protocol server. Service=trading_technologies.trading|SymbolSettings=trading_technologies_v2.trading. | 2019-11-01 08:04:01.300
SC Futures Order Routing/Data | Trading is supported. | 2019-11-01 08:04:01.300
SC Futures Order Routing/Data | Order cancel and replace is supported. | 2019-11-01 08:04:01.300
SC Futures Order Routing/Data | OCO Orders supported. | 2019-11-01 08:04:01.300
SC Futures Order Routing/Data | Bracket Orders supported. | 2019-11-01 08:04:01.302
SC Futures Order Routing/Data | Connected to data and trading server. | 2019-11-01 08:04:01.302
Triggering next historical data download in queue. | 2019-11-01 08:04:01.311
HD Request # 3 | Decompressing data. | 2019-11-01 08:04:01.348
HD Request # 3 | Receiving Intraday data for QMX19_FUT_NYMEX starting at 2019-10-21 13:29:49 | 2019-11-01 08:04:01.349
HD Request # 3 | Timestamp of first Intraday data file record written: 2019-10-21 13:29:49 | 2019-11-01 08:04:01.350
Socket (3) | Shutdown started. Waiting for graceful close. | 2019-11-01 08:04:01.350
HD Request # 3 | Re-requesting historical data for QMX19_FUT_NYMEX to get the latest data since the download was started while not connected to primary service. | 2019-11-01 08:04:01.354
Added Intraday data request for QMX19_FUT_NYMEX to the queue. | 2019-11-01 08:04:01.354
Triggering next historical data download in queue. | 2019-11-01 08:04:01.354
Historical data download thread signaled to stop. | 2019-11-01 08:04:01.354
HD Request # 3 | Received 1 record from 2019-10-21 13:29:49.000 to 2019-10-21 13:29:49.000 (0.0 seconds) and wrote 1 record for QMX19_FUT_NYMEX | 2019-11-01 08:04:01.354
HD Request # 3 | Completion time: 0s | 2019-11-01 08:04:01.361
HD Request # 4 | Downloading Intraday chart data for QMX19_FUT_NYMEX to the file QMX19_FUT_NYMEX.scid. Service: nymex | 2019-11-01 08:04:01.362
HD Request # 4 | Download start date-time: 2019-10-21 13:29:49.000 | 2019-11-01 08:04:01.362
HD Request # 4 | Using server: exchangehistdata2.sierracharts.com port 10150 | 2019-11-01 08:04:01.362
Socket (1) | Creating socket. | 2019-11-01 08:04:01.362
Socket (1) | Connecting to IP: 8.18.161.133. | 2019-11-01 08:04:01.362
SC Futures Order Routing/Data | Starting real-time market data updates for: CLX9-NYMEX. ID: 2 | 2019-11-01 08:04:01.363
SC Futures Order Routing/Data | Subscribing to streaming market data in the service client is not supported. Symbol: CLX9-NYMEX | 2019-11-01 08:04:01.363
SC Futures Order Routing/Data | Requesting security definition data for: CLX9-NYMEX. ID: 2 | 2019-11-01 08:04:01.373
No historical data client is currently set to download historical Intraday data for CLX9-NYMEX. | 2019-11-01 08:04:01.373
Real-time Intraday chart data file updates started for CLX9-NYMEX | 2019-11-01 08:04:01.374
Opened cached Intraday file: C:\SierraChart\Data\CLX9-NYMEX.scid | 2019-11-01 08:04:01.375
Intraday chart data file opened for CLX9-NYMEX | 2019-11-01 08:04:01.375
SC Futures Order Routing/Data | Starting real-time market data updates for: CLZ19_FUT_NYMEX. ID: 3 | 2019-11-01 08:04:01.397
SC Futures Order Routing/Data | Subscribing to streaming market data in the service client is not supported. Symbol: CLZ19_FUT_NYMEX | 2019-11-01 08:04:01.397
SC Futures Order Routing/Data | Requesting security definition data for: CLZ19_FUT_NYMEX. ID: 3 | 2019-11-01 08:04:01.397
Added Intraday data request for CLZ19_FUT_NYMEX to the queue. | 2019-11-01 08:04:01.397
Intraday data recording state for symbol CLZ19_FUT_NYMEX is set to download 'Pending'. | 2019-11-01 08:04:01.397
Triggering next historical data download in queue. | 2019-11-01 08:04:01.397
Socket (3) | Socket gracefully closed by remote side. | 2019-11-01 08:04:01.453
Socket (3) | Closed. | 2019-11-01 08:04:01.453
SC Futures Order Routing/Data | Received security definition for symbol CLX9-NYMEX | 2019-11-01 08:04:01.524
SC Futures Order Routing/Data | Received security definition for symbol CLZ19_FUT_NYMEX | 2019-11-01 08:04:01.524
HD Request # 4 | Setting DTC encoding to Binary VLS | 2019-11-01 08:04:01.567
HD Request # 4 | Sending historical data logon request message. | 2019-11-01 08:04:01.567
HD Request # 4 | Requesting Intraday data. Start date-time: 2019-10-21 13:29:49. Record interval: 1. Symbol: QMX19 | 2019-11-01 08:04:01.667
SC Futures Order Routing/Data | Starting real-time market data updates for: 6SM9-CME. ID: 4 | 2019-11-01 08:04:01.697
SC Futures Order Routing/Data | Subscribing to streaming market data in the service client is not supported. Symbol: 6SM9-CME | 2019-11-01 08:04:01.697
SC Futures Order Routing/Data | Requesting security definition data for: 6SM9-CME. ID: 4 | 2019-11-01 08:04:01.697
No historical data client is currently set to download historical Intraday data for 6SM9-CME. | 2019-11-01 08:04:01.697
Real-time Intraday chart data file updates started for 6SM9-CME | 2019-11-01 08:04:01.697
Opened cached Intraday file: C:\SierraChart\Data\6SM9-CME.scid | 2019-11-01 08:04:01.697
Intraday chart data file opened for 6SM9-CME | 2019-11-01 08:04:01.697
SC Futures Order Routing/Data | Starting real-time market data updates for: QMZ19_FUT_NYMEX. ID: 5 | 2019-11-01 08:04:01.698
SC Futures Order Routing/Data | Subscribing to streaming market data in the service client is not supported. Symbol: QMZ19_FUT_NYMEX | 2019-11-01 08:04:01.698
SC Futures Order Routing/Data | Requesting security definition data for: QMZ19_FUT_NYMEX. ID: 5 | 2019-11-01 08:04:01.698
HD Request # 4 | Decompressing data. | 2019-11-01 08:04:01.772
HD Request # 4 | Receiving Intraday data for QMX19_FUT_NYMEX starting at 2019-10-21 13:29:49 | 2019-11-01 08:04:01.772
HD Request # 4 | Timestamp of first Intraday data file record written: 2019-10-21 13:29:49 | 2019-11-01 08:04:01.773
Socket (1) | Shutdown started. Waiting for graceful close. | 2019-11-01 08:04:01.773
Historical data download thread signaled to stop. | 2019-11-01 08:04:01.775
HD Request # 4 | Received 1 record from 2019-10-21 13:29:49.000 to 2019-10-21 13:29:49.000 (0.0 seconds) and wrote 1 record for QMX19_FUT_NYMEX | 2019-11-01 08:04:01.775
HD Request # 4 | Completion time: 0s | 2019-11-01 08:04:01.779
HD Request # 4 | Intraday data download complete for QMX19_FUT_NYMEX. Unique request ID: 2 | 2019-11-01 08:04:01.779
Removed historical data download ID 2 | 2019-11-01 08:04:01.779
Real-time Intraday chart data file updates started for QMX19_FUT_NYMEX | 2019-11-01 08:04:01.779
Opened cached Intraday file: C:\SierraChart\Data\QMX19_FUT_NYMEX.scid | 2019-11-01 08:04:01.779
Intraday chart data file opened for QMX19_FUT_NYMEX | 2019-11-01 08:04:01.779
Triggering next historical data download in queue. | 2019-11-01 08:04:01.779
Delaying start of download for QMZ19_FUT_NYMEX | 2019-11-01 08:04:01.780
SC Futures Order Routing/Data | Received security definition for symbol 6SM9-CME | 2019-11-01 08:04:01.821
SC Futures Order Routing/Data | Received security definition for symbol QMZ19_FUT_NYMEX | 2019-11-01 08:04:01.821
Requesting market depth updates for: CLZ19_FUT_NYMEX if supported. | 2019-11-01 08:04:01.821
Separate subscription for market depth updates not supported. CLZ19_FUT_NYMEX | 2019-11-01 08:04:01.821
Socket (1) | Socket gracefully closed by remote side. | 2019-11-01 08:04:01.872
Socket (1) | Closed. | 2019-11-01 08:04:01.872
SC Futures Order Routing/Data | Starting real-time market data updates for: QMX19_FUT_NYMEX. ID: 1 | 2019-11-01 08:04:01.920
SC Futures Order Routing/Data | Subscribing to streaming market data in the service client is not supported. Symbol: QMX19_FUT_NYMEX | 2019-11-01 08:04:01.920
SC Futures Order Routing/Data | Requesting security definition data for: QMX19_FUT_NYMEX. ID: 1 | 2019-11-01 08:04:01.920
SC Futures Order Routing/Data | Received security definition for symbol QMX19_FUT_NYMEX | 2019-11-01 08:04:02.034
HD Request # 5 | Downloading Intraday chart data for QMZ19_FUT_NYMEX to the file QMZ19_FUT_NYMEX.scid. Service: nymex | 2019-11-01 08:04:06.164
HD Request # 5 | Download start date-time: 2019-11-01 07:46:57.000 | 2019-11-01 08:04:06.165
HD Request # 5 | Using server: exchangehistdata1.sierracharts.com port 10149 | 2019-11-01 08:04:06.166
Socket (1) | Creating socket. | 2019-11-01 08:04:06.166
Socket (1) | Connecting to IP: 8.18.161.135. | 2019-11-01 08:04:06.166
HD Request # 5 | Setting DTC encoding to Binary VLS | 2019-11-01 08:04:06.380
HD Request # 5 | Sending historical data logon request message. | 2019-11-01 08:04:06.380
HD Request # 5 | Requesting Intraday data. Start date-time: 2019-11-01 07:46:57. Record interval: 1. Symbol: QMZ19 | 2019-11-01 08:04:06.476
HD Request # 5 | Decompressing data. | 2019-11-01 08:04:06.573
HD Request # 5 | Receiving Intraday data for QMZ19_FUT_NYMEX starting at 2019-11-01 07:46:57 | 2019-11-01 08:04:06.573
HD Request # 5 | Timestamp of first Intraday data file record written: 2019-11-01 07:46:57 | 2019-11-01 08:04:06.574
Socket (1) | Shutdown started. Waiting for graceful close. | 2019-11-01 08:04:06.574
Historical data download thread signaled to stop. | 2019-11-01 08:04:06.574
HD Request # 5 | Received 69 records from 2019-11-01 07:46:57.000 to 2019-11-01 07:54:06.000 (7.1 minutes) and wrote 69 records for QMZ19_FUT_NYMEX | 2019-11-01 08:04:06.574
HD Request # 5 | Completion time: 0s | 2019-11-01 08:04:06.584
HD Request # 5 | Intraday data download complete for QMZ19_FUT_NYMEX. Unique request ID: 3 | 2019-11-01 08:04:06.584
Removed historical data download ID 3 | 2019-11-01 08:04:06.584
Real-time Intraday chart data file updates started for QMZ19_FUT_NYMEX | 2019-11-01 08:04:06.584
Opened cached Intraday file: C:\SierraChart\Data\QMZ19_FUT_NYMEX.scid | 2019-11-01 08:04:06.584
Intraday chart data file opened for QMZ19_FUT_NYMEX | 2019-11-01 08:04:06.584
Triggering next historical data download in queue. | 2019-11-01 08:04:06.584
HD Request # 6 | Downloading Intraday chart data for CLZ19_FUT_NYMEX to the file CLZ19_FUT_NYMEX.scid. Service: nymex | 2019-11-01 08:04:06.585
HD Request # 6 | Download start date-time: 2019-11-01 07:54:01.000 | 2019-11-01 08:04:06.585
HD Request # 6 | Using server: exchangehistdata2.sierracharts.com port 10150 | 2019-11-01 08:04:06.585
Socket (3) | Creating socket. | 2019-11-01 08:04:06.585
Socket (3) | Connecting to IP: 8.18.161.133. | 2019-11-01 08:04:06.585
Socket (1) | Socket gracefully closed by remote side. | 2019-11-01 08:04:06.677
Socket (1) | Closed. | 2019-11-01 08:04:06.677
HD Request # 6 | Setting DTC encoding to Binary VLS | 2019-11-01 08:04:06.791
HD Request # 6 | Sending historical data logon request message. | 2019-11-01 08:04:06.791
HD Request # 6 | Requesting Intraday data. Start date-time: 2019-11-01 07:54:01. Record interval: 1. Symbol: CLZ19 | 2019-11-01 08:04:06.890
HD Request # 6 | Decompressing data. | 2019-11-01 08:04:06.988
HD Request # 6 | Receiving Intraday data for CLZ19_FUT_NYMEX starting at 2019-11-01 07:54:01 | 2019-11-01 08:04:06.988
HD Request # 6 | Timestamp of first Intraday data file record written: 2019-11-01 07:54:01 | 2019-11-01 08:04:06.989
Socket (3) | Shutdown started. Waiting for graceful close. | 2019-11-01 08:04:06.989
Historical data download thread signaled to stop. | 2019-11-01 08:04:07.008
HD Request # 6 | Received 6 records from 2019-11-01 07:54:01.000 to 2019-11-01 07:54:07.000 (6.0 seconds) and wrote 6 records for CLZ19_FUT_NYMEX | 2019-11-01 08:04:07.008
HD Request # 6 | Completion time: 1s | 2019-11-01 08:04:07.013
HD Request # 6 | Intraday data download complete for CLZ19_FUT_NYMEX. Unique request ID: 4 | 2019-11-01 08:04:07.013
Removed historical data download ID 4 | 2019-11-01 08:04:07.013
Real-time Intraday chart data file updates started for CLZ19_FUT_NYMEX | 2019-11-01 08:04:07.013
Opened cached Intraday file: C:\SierraChart\Data\CLZ19_FUT_NYMEX.scid | 2019-11-01 08:04:07.013
Intraday chart data file opened for CLZ19_FUT_NYMEX | 2019-11-01 08:04:07.013
Triggering next historical data download in queue. | 2019-11-01 08:04:07.013
Socket (3) | Socket gracefully closed by remote side. | 2019-11-01 08:04:07.090
Socket (3) | Closed. | 2019-11-01 08:04:07.090
CLZ19_FUT_NYMEX 1 Min #11 | Reloading chart. | 2019-11-01 08:13:46.870
SC Futures Order Routing/Data | Performing periodic download of Intraday data for open Intraday charts not receiving real-time data | 2019-11-01 08:25:01.347
Added Intraday data request for CLZ19_FUT_NYMEX to the queue. | 2019-11-01 08:25:01.347
Intraday data recording state for symbol CLZ19_FUT_NYMEX is set to download 'Pending'. | 2019-11-01 08:25:01.347
Triggering next historical data download in queue. | 2019-11-01 08:25:01.347
Added Intraday data request for QMZ19_FUT_NYMEX to the queue. | 2019-11-01 08:25:01.347
Intraday data recording state for symbol QMZ19_FUT_NYMEX is set to download 'Pending'. | 2019-11-01 08:25:01.347
HD Request # 7 | Downloading Intraday chart data for CLZ19_FUT_NYMEX to the file CLZ19_FUT_NYMEX.scid. Service: nymex | 2019-11-01 08:25:01.347
HD Request # 7 | Download start date-time: 2019-11-01 07:54:07.000 | 2019-11-01 08:25:01.348
HD Request # 7 | Using server: exchangehistdata1.sierracharts.com port 10149 | 2019-11-01 08:25:01.348
Socket (1) | Creating socket. | 2019-11-01 08:25:01.349
Socket (1) | Connecting to IP: 8.18.161.135. | 2019-11-01 08:25:01.349
HD Request # 7 | Setting DTC encoding to Binary VLS | 2019-11-01 08:25:01.563
HD Request # 7 | Sending historical data logon request message. | 2019-11-01 08:25:01.563
HD Request # 7 | Requesting Intraday data. Start date-time: 2019-11-01 07:54:07. Record interval: 1. Symbol: CLZ19 | 2019-11-01 08:25:01.666
HD Request # 7 | Decompressing data. | 2019-11-01 08:25:01.945
HD Request # 7 | Receiving Intraday data for CLZ19_FUT_NYMEX starting at 2019-11-01 07:54:07 | 2019-11-01 08:25:02.153
HD Request # 7 | Timestamp of first Intraday data file record written: 2019-11-01 07:54:07 | 2019-11-01 08:25:02.154
Socket (1) | Shutdown started. Waiting for graceful close. | 2019-11-01 08:25:02.154
Historical data download thread signaled to stop. | 2019-11-01 08:25:02.159
HD Request # 7 | Received 1076 records from 2019-11-01 07:54:07.000 to 2019-11-01 08:15:03.000 (20.9 minutes) and wrote 1076 records for CLZ19_FUT_NYMEX | 2019-11-01 08:25:02.159
HD Request # 7 | Completion time: 0s | 2019-11-01 08:25:02.167
HD Request # 7 | Intraday data download complete for CLZ19_FUT_NYMEX. Unique request ID: 5 | 2019-11-01 08:25:02.167
Removed historical data download ID 5 | 2019-11-01 08:25:02.167
Real-time Intraday chart data file updates started for CLZ19_FUT_NYMEX | 2019-11-01 08:25:02.167
Opened cached Intraday file: C:\SierraChart\Data\CLZ19_FUT_NYMEX.scid | 2019-11-01 08:25:02.167
Intraday chart data file opened for CLZ19_FUT_NYMEX | 2019-11-01 08:25:02.167
Triggering next historical data download in queue. | 2019-11-01 08:25:02.167
HD Request # 8 | Downloading Intraday chart data for QMZ19_FUT_NYMEX to the file QMZ19_FUT_NYMEX.scid. Service: nymex | 2019-11-01 08:25:02.167
HD Request # 8 | Download start date-time: 2019-11-01 07:54:06.000 | 2019-11-01 08:25:02.168
HD Request # 8 | Using server: exchangehistdata2.sierracharts.com port 10150 | 2019-11-01 08:25:02.168
Socket (3) | Creating socket. | 2019-11-01 08:25:02.169
Socket (3) | Connecting to IP: 8.18.161.133. | 2019-11-01 08:25:02.169
Socket (1) | Socket gracefully closed by remote side. | 2019-11-01 08:25:02.259
Socket (1) | Closed. | 2019-11-01 08:25:02.259
HD Request # 8 | Setting DTC encoding to Binary VLS | 2019-11-01 08:25:02.385
HD Request # 8 | Sending historical data logon request message. | 2019-11-01 08:25:02.385
HD Request # 8 | Requesting Intraday data. Start date-time: 2019-11-01 07:54:06. Record interval: 1. Symbol: QMZ19 | 2019-11-01 08:25:02.487
HD Request # 8 | Decompressing data. | 2019-11-01 08:25:02.591
HD Request # 8 | Receiving Intraday data for QMZ19_FUT_NYMEX starting at 2019-11-01 07:54:06 | 2019-11-01 08:25:02.591
HD Request # 8 | Timestamp of first Intraday data file record written: 2019-11-01 07:54:06 | 2019-11-01 08:25:02.592
Socket (3) | Shutdown started. Waiting for graceful close. | 2019-11-01 08:25:02.592
Historical data download thread signaled to stop. | 2019-11-01 08:25:02.598
HD Request # 8 | Received 261 records from 2019-11-01 07:54:06.000 to 2019-11-01 08:15:01.000 (20.9 minutes) and wrote 261 records for QMZ19_FUT_NYMEX | 2019-11-01 08:25:02.598
HD Request # 8 | Completion time: 0s | 2019-11-01 08:25:02.602
HD Request # 8 | Intraday data download complete for QMZ19_FUT_NYMEX. Unique request ID: 6 | 2019-11-01 08:25:02.602
Removed historical data download ID 6 | 2019-11-01 08:25:02.602
Real-time Intraday chart data file updates started for QMZ19_FUT_NYMEX | 2019-11-01 08:25:02.602
Opened cached Intraday file: C:\SierraChart\Data\QMZ19_FUT_NYMEX.scid | 2019-11-01 08:25:02.602
Intraday chart data file opened for QMZ19_FUT_NYMEX | 2019-11-01 08:25:02.602
Triggering next historical data download in queue. | 2019-11-01 08:25:02.602
Socket (3) | Socket gracefully closed by remote side. | 2019-11-01 08:25:02.698
Socket (3) | Closed. | 2019-11-01 08:25:02.698
SC Futures Order Routing/Data | Performing periodic download of Intraday data for open Intraday charts not receiving real-time data | 2019-11-01 08:45:01.349
Added Intraday data request for CLZ19_FUT_NYMEX to the queue. | 2019-11-01 08:45:01.350
Intraday data recording state for symbol CLZ19_FUT_NYMEX is set to download 'Pending'. | 2019-11-01 08:45:01.350
Triggering next historical data download in queue. | 2019-11-01 08:45:01.350
Added Intraday data request for QMZ19_FUT_NYMEX to the queue. | 2019-11-01 08:45:01.350
Intraday data recording state for symbol QMZ19_FUT_NYMEX is set to download 'Pending'. | 2019-11-01 08:45:01.350
HD Request # 9 | Downloading Intraday chart data for CLZ19_FUT_NYMEX to the file CLZ19_FUT_NYMEX.scid. Service: nymex | 2019-11-01 08:45:01.350
HD Request # 9 | Download start date-time: 2019-11-01 08:15:03.000 | 2019-11-01 08:45:01.350
HD Request # 9 | Using server: exchangehistdata1.sierracharts.com port 10149 | 2019-11-01 08:45:01.350
Socket (1) | Creating socket. | 2019-11-01 08:45:01.352
Socket (1) | Connecting to IP: 8.18.161.135. | 2019-11-01 08:45:01.352
HD Request # 9 | Setting DTC encoding to Binary VLS | 2019-11-01 08:45:01.566
HD Request # 9 | Sending historical data logon request message. | 2019-11-01 08:45:01.566
HD Request # 9 | Requesting Intraday data. Start date-time: 2019-11-01 08:15:03. Record interval: 1. Symbol: CLZ19 | 2019-11-01 08:45:01.670
HD Request # 9 | Decompressing data. | 2019-11-01 08:45:01.824
HD Request # 9 | Receiving Intraday data for CLZ19_FUT_NYMEX starting at 2019-11-01 08:15:03 | 2019-11-01 08:45:02.097
HD Request # 9 | Timestamp of first Intraday data file record written: 2019-11-01 08:15:03 | 2019-11-01 08:45:02.097
Socket (1) | Shutdown started. Waiting for graceful close. | 2019-11-01 08:45:02.098
Historical data download thread signaled to stop. | 2019-11-01 08:45:02.098
HD Request # 9 | Received 1072 records from 2019-11-01 08:15:03.000 to 2019-11-01 08:35:02.000 (20.0 minutes) and wrote 1072 records for CLZ19_FUT_NYMEX | 2019-11-01 08:45:02.098
HD Request # 9 | Completion time: 1s | 2019-11-01 08:45:02.104
HD Request # 9 | Intraday data download complete for CLZ19_FUT_NYMEX. Unique request ID: 7 | 2019-11-01 08:45:02.104
Removed historical data download ID 7 | 2019-11-01 08:45:02.104
Real-time Intraday chart data file updates started for CLZ19_FUT_NYMEX | 2019-11-01 08:45:02.104
Opened cached Intraday file: C:\SierraChart\Data\CLZ19_FUT_NYMEX.scid | 2019-11-01 08:45:02.104
Intraday chart data file opened for CLZ19_FUT_NYMEX | 2019-11-01 08:45:02.104
Triggering next historical data download in queue. | 2019-11-01 08:45:02.104
HD Request # 10 | Downloading Intraday chart data for QMZ19_FUT_NYMEX to the file QMZ19_FUT_NYMEX.scid. Service: nymex | 2019-11-01 08:45:02.105
HD Request # 10 | Download start date-time: 2019-11-01 08:15:01.000 | 2019-11-01 08:45:02.105
HD Request # 10 | Using server: exchangehistdata2.sierracharts.com port 10150 | 2019-11-01 08:45:02.105
Socket (3) | Creating socket. | 2019-11-01 08:45:02.106
Socket (3) | Connecting to IP: 8.18.161.133. | 2019-11-01 08:45:02.106
Socket (1) | Socket gracefully closed by remote side. | 2019-11-01 08:45:02.199
Socket (1) | Closed. | 2019-11-01 08:45:02.200
HD Request # 10 | Setting DTC encoding to Binary VLS | 2019-11-01 08:45:02.323
HD Request # 10 | Sending historical data logon request message. | 2019-11-01 08:45:02.323
HD Request # 10 | Requesting Intraday data. Start date-time: 2019-11-01 08:15:01. Record interval: 1. Symbol: QMZ19 | 2019-11-01 08:45:02.425
HD Request # 10 | Decompressing data. | 2019-11-01 08:45:02.523
HD Request # 10 | Receiving Intraday data for QMZ19_FUT_NYMEX starting at 2019-11-01 08:15:01 | 2019-11-01 08:45:02.525
HD Request # 10 | Timestamp of first Intraday data file record written: 2019-11-01 08:15:01 | 2019-11-01 08:45:02.525
Socket (3) | Shutdown started. Waiting for graceful close. | 2019-11-01 08:45:02.526
Historical data download thread signaled to stop. | 2019-11-01 08:45:02.551
HD Request # 10 | Received 305 records from 2019-11-01 08:15:01.000 to 2019-11-01 08:35:02.000 (20.0 minutes) and wrote 305 records for QMZ19_FUT_NYMEX | 2019-11-01 08:45:02.551
HD Request # 10 | Completion time: 0s | 2019-11-01 08:45:02.555
HD Request # 10 | Intraday data download complete for QMZ19_FUT_NYMEX. Unique request ID: 8 | 2019-11-01 08:45:02.555
Removed historical data download ID 8 | 2019-11-01 08:45:02.555
Real-time Intraday chart data file updates started for QMZ19_FUT_NYMEX | 2019-11-01 08:45:02.555
Opened cached Intraday file: C:\SierraChart\Data\QMZ19_FUT_NYMEX.scid | 2019-11-01 08:45:02.556
Intraday chart data file opened for QMZ19_FUT_NYMEX | 2019-11-01 08:45:02.556
Triggering next historical data download in queue. | 2019-11-01 08:45:02.556
Socket (3) | Socket gracefully closed by remote side. | 2019-11-01 08:45:02.625
Socket (3) | Closed. | 2019-11-01 08:45:02.625
SC Futures Order Routing/Data | Performing periodic download of Intraday data for open Intraday charts not receiving real-time data | 2019-11-01 09:05:01.355
Added Intraday data request for CLZ19_FUT_NYMEX to the queue. | 2019-11-01 09:05:01.355
Intraday data recording state for symbol CLZ19_FUT_NYMEX is set to download 'Pending'. | 2019-11-01 09:05:01.355
Triggering next historical data download in queue. | 2019-11-01 09:05:01.355
Added Intraday data request for QMZ19_FUT_NYMEX to the queue. | 2019-11-01 09:05:01.355
Intraday data recording state for symbol QMZ19_FUT_NYMEX is set to download 'Pending'. | 2019-11-01 09:05:01.355
HD Request # 11 | Downloading Intraday chart data for CLZ19_FUT_NYMEX to the file CLZ19_FUT_NYMEX.scid. Service: nymex | 2019-11-01 09:05:01.355
HD Request # 11 | Download start date-time: 2019-11-01 08:35:02.000 | 2019-11-01 09:05:01.356
HD Request # 11 | Using server: exchangehistdata1.sierracharts.com port 10149 | 2019-11-01 09:05:01.356
Socket (1) | Creating socket. | 2019-11-01 09:05:01.357
Socket (1) | Connecting to IP: 8.18.161.135. | 2019-11-01 09:05:01.357
HD Request # 11 | Setting DTC encoding to Binary VLS | 2019-11-01 09:05:01.563
HD Request # 11 | Sending historical data logon request message. | 2019-11-01 09:05:01.563
HD Request # 11 | Requesting Intraday data. Start date-time: 2019-11-01 08:35:02. Record interval: 1. Symbol: CLZ19 | 2019-11-01 09:05:01.663
HD Request # 11 | Decompressing data. | 2019-11-01 09:05:01.888
HD Request # 11 | Receiving Intraday data for CLZ19_FUT_NYMEX starting at 2019-11-01 08:35:02 | 2019-11-01 09:05:02.175
HD Request # 11 | Timestamp of first Intraday data file record written: 2019-11-01 08:35:02 | 2019-11-01 09:05:02.175
Socket (1) | Shutdown started. Waiting for graceful close. | 2019-11-01 09:05:02.175
Historical data download thread signaled to stop. | 2019-11-01 09:05:02.176
HD Request # 11 | Received 961 records from 2019-11-01 08:35:02.000 to 2019-11-01 08:55:03.000 (20.0 minutes) and wrote 961 records for CLZ19_FUT_NYMEX | 2019-11-01 09:05:02.176
HD Request # 11 | Completion time: 1s | 2019-11-01 09:05:02.180
HD Request # 11 | Intraday data download complete for CLZ19_FUT_NYMEX. Unique request ID: 9 | 2019-11-01 09:05:02.180
Removed historical data download ID 9 | 2019-11-01 09:05:02.180
Real-time Intraday chart data file updates started for CLZ19_FUT_NYMEX | 2019-11-01 09:05:02.180
Opened cached Intraday file: C:\SierraChart\Data\CLZ19_FUT_NYMEX.scid | 2019-11-01 09:05:02.180
Intraday chart data file opened for CLZ19_FUT_NYMEX | 2019-11-01 09:05:02.181
Triggering next historical data download in queue. | 2019-11-01 09:05:02.181
HD Request # 12 | Downloading Intraday chart data for QMZ19_FUT_NYMEX to the file QMZ19_FUT_NYMEX.scid. Service: nymex | 2019-11-01 09:05:02.181
HD Request # 12 | Download start date-time: 2019-11-01 08:35:02.000 | 2019-11-01 09:05:02.181
HD Request # 12 | Using server: exchangehistdata2.sierracharts.com port 10150 | 2019-11-01 09:05:02.181
Socket (3) | Creating socket. | 2019-11-01 09:05:02.182
Socket (3) | Connecting to IP: 8.18.161.133. | 2019-11-01 09:05:02.182
Socket (1) | Socket gracefully closed by remote side. | 2019-11-01 09:05:02.274
Socket (1) | Closed. | 2019-11-01 09:05:02.274
HD Request # 12 | Setting DTC encoding to Binary VLS | 2019-11-01 09:05:02.393
HD Request # 12 | Sending historical data logon request message. | 2019-11-01 09:05:02.393
HD Request # 12 | Requesting Intraday data. Start date-time: 2019-11-01 08:35:02. Record interval: 1. Symbol: QMZ19 | 2019-11-01 09:05:02.492
HD Request # 12 | Decompressing data. | 2019-11-01 09:05:02.592
HD Request # 12 | Receiving Intraday data for QMZ19_FUT_NYMEX starting at 2019-11-01 08:35:02 | 2019-11-01 09:05:02.592
HD Request # 12 | Timestamp of first Intraday data file record written: 2019-11-01 08:35:02 | 2019-11-01 09:05:02.593
Socket (3) | Shutdown started. Waiting for graceful close. | 2019-11-01 09:05:02.593
Historical data download thread signaled to stop. | 2019-11-01 09:05:02.594
HD Request # 12 | Received 217 records from 2019-11-01 08:35:02.000 to 2019-11-01 08:55:03.000 (20.0 minutes) and wrote 217 records for QMZ19_FUT_NYMEX | 2019-11-01 09:05:02.594
HD Request # 12 | Completion time: 0s | 2019-11-01 09:05:02.603
HD Request # 12 | Intraday data download complete for QMZ19_FUT_NYMEX. Unique request ID: 10 | 2019-11-01 09:05:02.603
Removed historical data download ID 10 | 2019-11-01 09:05:02.603
Real-time Intraday chart data file updates started for QMZ19_FUT_NYMEX | 2019-11-01 09:05:02.603
Opened cached Intraday file: C:\SierraChart\Data\QMZ19_FUT_NYMEX.scid | 2019-11-01 09:05:02.603
Intraday chart data file opened for QMZ19_FUT_NYMEX | 2019-11-01 09:05:02.603
Triggering next historical data download in queue. | 2019-11-01 09:05:02.604
Socket (3) | Socket gracefully closed by remote side. | 2019-11-01 09:05:02.695
Socket (3) | Closed. | 2019-11-01 09:05:02.695
CLX9-NYMEX 2584 Trades #13 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-11-01 09:12:50.591
CLZ19_FUT_NYMEX 2584 Trades #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-11-01 09:12:50.610
CLZ19_FUT_NYMEX 1597 Volume #8 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-11-01 09:12:50.611
CLZ19_FUT_NYMEX 6765 Trades #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-11-01 09:12:50.642
CLZ19_FUT_NYMEX 6765 Trades #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-11-01 09:12:50.643
6SM9-CME 50 Trades #7 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-11-01 09:12:50.660
QMZ19_FUT_NYMEX 50 Trades #13 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-11-01 09:12:50.662
CLZ19_FUT_NYMEX 10976 Volume #6 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-11-01 09:12:50.764
CLX9-NYMEX 10946 Trades #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-11-01 09:12:50.819
CLZ19_FUT_NYMEX 5 Min #12 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-11-01 09:12:50.830
CLZ19_FUT_NYMEX 4181 Volume #10 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-11-01 09:12:50.840
CLZ19_FUT_NYMEX 6765 Volume #7 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-11-01 09:12:50.854
CLZ19_FUT_NYMEX 10976 Volume #6 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-11-01 09:12:50.899
CLX9-NYMEX 10946 Volume #5 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-11-01 09:12:50.901
CLZ19_FUT_NYMEX 10976 Trades #5 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-11-01 09:12:50.903
CLZ19_FUT_NYMEX 1597 Trades #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-11-01 09:12:50.968
CLZ19_FUT_NYMEX 4181 Volume #10 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-11-01 09:12:50.973
CLZ19_FUT_NYMEX 4181 Trades #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-11-01 09:12:51.021
CLZ19_FUT_NYMEX 1597 Trades #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-11-01 09:12:51.064
CLZ19_FUT_NYMEX 4181 Trades #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-11-01 09:12:51.133
CLZ19_FUT_NYMEX 2584 Volume #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-11-01 09:12:51.134
CLZ19_FUT_NYMEX 5 Min #12 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-11-01 09:12:51.136
CLX9-NYMEX 4181 Trades #8 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-11-01 09:12:51.162
CLZ19_FUT_NYMEX 10976 Trades #5 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-11-01 09:12:51.216
QMX19_FUT_NYMEX 50 Trades #13 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-11-01 09:12:51.219
CLZ19_FUT_NYMEX 2584 Volume #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-11-01 09:12:51.222
CLX9-NYMEX 1597 Trades #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-11-01 09:12:51.294
CLZ19_FUT_NYMEX 2584 Trades #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-11-01 09:12:51.297
CLZ19_FUT_NYMEX 6765 Volume #7 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-11-01 09:12:51.342
CLZ19_FUT_NYMEX 1597 Volume #8 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-11-01 09:12:51.358
CLZ19_FUT_NYMEX 2584 Trades #2 | StartDateTimeForLoadingOrderFills: 2019-10-31 17:00:00 | 2019-11-01 09:13:00.017
CLZ19_FUT_NYMEX 1597 Volume #8 | StartDateTimeForLoadingOrderFills: 2019-10-31 17:00:00 | 2019-11-01 09:13:00.019
CLZ19_FUT_NYMEX 6765 Trades #4 | StartDateTimeForLoadingOrderFills: 2019-10-31 17:00:00 | 2019-11-01 09:13:00.088
CLZ19_FUT_NYMEX 6765 Trades #4 | StartDateTimeForLoadingOrderFills: 2019-10-31 17:00:00 | 2019-11-01 09:13:00.090
6SM9-CME 50 Trades #7 | StartDateTimeForLoadingOrderFills: 2019-05-19 17:00:00 | 2019-11-01 09:13:00.130
QMZ19_FUT_NYMEX 50 Trades #13 | StartDateTimeForLoadingOrderFills: 2019-10-31 23:00:00 | 2019-11-01 09:13:00.132
CLZ19_FUT_NYMEX 10976 Volume #6 | StartDateTimeForLoadingOrderFills: 2019-10-31 17:00:00 | 2019-11-01 09:13:00.140
CLX9-NYMEX 10946 Trades #4 | StartDateTimeForLoadingOrderFills: 2019-07-21 17:00:00 | 2019-11-01 09:13:00.167
CLZ19_FUT_NYMEX 5 Min #12 | StartDateTimeForLoadingOrderFills: 2019-10-31 17:00:00 | 2019-11-01 09:13:00.176
CLZ19_FUT_NYMEX 4181 Volume #10 | StartDateTimeForLoadingOrderFills: 2019-10-31 17:00:00 | 2019-11-01 09:13:00.177
CLZ19_FUT_NYMEX 6765 Volume #7 | StartDateTimeForLoadingOrderFills: 2019-10-31 17:00:00 | 2019-11-01 09:13:00.179
CLZ19_FUT_NYMEX 10976 Volume #6 | StartDateTimeForLoadingOrderFills: 2019-10-31 17:00:00 | 2019-11-01 09:13:00.199
CLX9-NYMEX 10946 Volume #5 | StartDateTimeForLoadingOrderFills: 2019-07-21 17:00:00 | 2019-11-01 09:13:00.202
CLZ19_FUT_NYMEX 10976 Trades #5 | StartDateTimeForLoadingOrderFills: 2019-10-31 17:00:00 | 2019-11-01 09:13:00.206
CLZ19_FUT_NYMEX 1597 Trades #1 | StartDateTimeForLoadingOrderFills: 2019-10-31 17:00:00 | 2019-11-01 09:13:00.236
CLZ19_FUT_NYMEX 4181 Volume #10 | StartDateTimeForLoadingOrderFills: 2019-10-31 17:00:00 | 2019-11-01 09:13:00.239
CLZ19_FUT_NYMEX 4181 Trades #3 | StartDateTimeForLoadingOrderFills: 2019-10-31 17:00:00 | 2019-11-01 09:13:00.262
CLZ19_FUT_NYMEX 1597 Trades #1 | StartDateTimeForLoadingOrderFills: 2019-10-31 17:00:00 | 2019-11-01 09:13:00.284
CLZ19_FUT_NYMEX 4181 Trades #3 | StartDateTimeForLoadingOrderFills: 2019-10-31 17:00:00 | 2019-11-01 09:13:00.320
CLZ19_FUT_NYMEX 2584 Volume #9 | StartDateTimeForLoadingOrderFills: 2019-10-31 17:00:00 | 2019-11-01 09:13:00.321
CLZ19_FUT_NYMEX 5 Min #12 | StartDateTimeForLoadingOrderFills: 2019-10-31 17:00:00 | 2019-11-01 09:13:00.323
CLX9-NYMEX 4181 Trades #8 | StartDateTimeForLoadingOrderFills: 2019-07-21 17:00:00 | 2019-11-01 09:13:00.341
CLZ19_FUT_NYMEX 10976 Trades #5 | StartDateTimeForLoadingOrderFills: 2019-10-31 17:00:00 | 2019-11-01 09:13:00.357
QMX19_FUT_NYMEX 50 Trades #13 | StartDateTimeForLoadingOrderFills: 2019-10-20 17:00:00 | 2019-11-01 09:13:00.360
CLZ19_FUT_NYMEX 2584 Volume #9 | StartDateTimeForLoadingOrderFills: 2019-10-31 17:00:00 | 2019-11-01 09:13:00.362
CLX9-NYMEX 1597 Trades #2 | StartDateTimeForLoadingOrderFills: 2019-08-19 17:00:00 | 2019-11-01 09:13:00.386
CLZ19_FUT_NYMEX 2584 Trades #2 | StartDateTimeForLoadingOrderFills: 2019-10-31 17:00:00 | 2019-11-01 09:13:00.388
CLZ19_FUT_NYMEX 6765 Volume #7 | StartDateTimeForLoadingOrderFills: 2019-10-31 17:00:00 | 2019-11-01 09:13:00.417
CLZ19_FUT_NYMEX 1597 Volume #8 | StartDateTimeForLoadingOrderFills: 2019-10-31 17:00:00 | 2019-11-01 09:13:00.436
CLX9-NYMEX 2584 Trades #13 | StartDateTimeForLoadingOrderFills: 2019-07-21 17:00:00 | 2019-11-01 09:13:00.440
SC Futures Order Routing/Data | Performing periodic download of Intraday data for open Intraday charts not receiving real-time data | 2019-11-01 09:25:01.355
Added Intraday data request for CLZ19_FUT_NYMEX to the queue. | 2019-11-01 09:25:01.355
Intraday data recording state for symbol CLZ19_FUT_NYMEX is set to download 'Pending'. | 2019-11-01 09:25:01.355
Triggering next historical data download in queue. | 2019-11-01 09:25:01.355
Added Intraday data request for QMZ19_FUT_NYMEX to the queue. | 2019-11-01 09:25:01.355
Intraday data recording state for symbol QMZ19_FUT_NYMEX is set to download 'Pending'. | 2019-11-01 09:25:01.355
HD Request # 13 | Downloading Intraday chart data for CLZ19_FUT_NYMEX to the file CLZ19_FUT_NYMEX.scid. Service: nymex | 2019-11-01 09:25:01.355
HD Request # 13 | Download start date-time: 2019-11-01 08:55:03.000 | 2019-11-01 09:25:01.356
HD Request # 13 | Using server: exchangehistdata1.sierracharts.com port 10149 | 2019-11-01 09:25:01.356
Socket (1) | Creating socket. | 2019-11-01 09:25:01.357
Socket (1) | Connecting to IP: 8.18.161.135. | 2019-11-01 09:25:01.357
HD Request # 13 | Setting DTC encoding to Binary VLS | 2019-11-01 09:25:01.573
HD Request # 13 | Sending historical data logon request message. | 2019-11-01 09:25:01.573
HD Request # 13 | Requesting Intraday data. Start date-time: 2019-11-01 08:55:03. Record interval: 1. Symbol: CLZ19 | 2019-11-01 09:25:01.677
HD Request # 13 | Decompressing data. | 2019-11-01 09:25:01.905
HD Request # 13 | Receiving Intraday data for CLZ19_FUT_NYMEX starting at 2019-11-01 08:55:03 | 2019-11-01 09:25:02.126
HD Request # 13 | Timestamp of first Intraday data file record written: 2019-11-01 08:55:03 | 2019-11-01 09:25:02.126
Socket (1) | Shutdown started. Waiting for graceful close. | 2019-11-01 09:25:02.127
Historical data download thread signaled to stop. | 2019-11-01 09:25:02.127
HD Request # 13 | Received 968 records from 2019-11-01 08:55:03.000 to 2019-11-01 09:15:03.000 (20.0 minutes) and wrote 968 records for CLZ19_FUT_NYMEX | 2019-11-01 09:25:02.128
HD Request # 13 | Completion time: 0s | 2019-11-01 09:25:02.133
HD Request # 13 | Intraday data download complete for CLZ19_FUT_NYMEX. Unique request ID: 11 | 2019-11-01 09:25:02.133
Removed historical data download ID 11 | 2019-11-01 09:25:02.133
Real-time Intraday chart data file updates started for CLZ19_FUT_NYMEX | 2019-11-01 09:25:02.133
Opened cached Intraday file: C:\SierraChart\Data\CLZ19_FUT_NYMEX.scid | 2019-11-01 09:25:02.133
Intraday chart data file opened for CLZ19_FUT_NYMEX | 2019-11-01 09:25:02.133
Triggering next historical data download in queue. | 2019-11-01 09:25:02.133
HD Request # 14 | Downloading Intraday chart data for QMZ19_FUT_NYMEX to the file QMZ19_FUT_NYMEX.scid. Service: nymex | 2019-11-01 09:25:02.133
HD Request # 14 | Download start date-time: 2019-11-01 08:55:03.000 | 2019-11-01 09:25:02.134
HD Request # 14 | Using server: exchangehistdata2.sierracharts.com port 10150 | 2019-11-01 09:25:02.134
Socket (3) | Creating socket. | 2019-11-01 09:25:02.135
Socket (3) | Connecting to IP: 8.18.161.133. | 2019-11-01 09:25:02.135
Socket (1) | Socket gracefully closed by remote side. | 2019-11-01 09:25:02.230
Socket (1) | Closed. | 2019-11-01 09:25:02.230
HD Request # 14 | Setting DTC encoding to Binary VLS | 2019-11-01 09:25:02.341
HD Request # 14 | Sending historical data logon request message. | 2019-11-01 09:25:02.341
HD Request # 14 | Requesting Intraday data. Start date-time: 2019-11-01 08:55:03. Record interval: 1. Symbol: QMZ19 | 2019-11-01 09:25:02.439
HD Request # 14 | Decompressing data. | 2019-11-01 09:25:02.539
HD Request # 14 | Receiving Intraday data for QMZ19_FUT_NYMEX starting at 2019-11-01 08:55:03 | 2019-11-01 09:25:02.539
HD Request # 14 | Timestamp of first Intraday data file record written: 2019-11-01 08:55:03 | 2019-11-01 09:25:02.540
Socket (3) | Shutdown started. Waiting for graceful close. | 2019-11-01 09:25:02.540
Historical data download thread signaled to stop. | 2019-11-01 09:25:02.563
HD Request # 14 | Received 271 records from 2019-11-01 08:55:03.000 to 2019-11-01 09:15:03.000 (20.0 minutes) and wrote 271 records for QMZ19_FUT_NYMEX | 2019-11-01 09:25:02.564
HD Request # 14 | Completion time: 0s | 2019-11-01 09:25:02.568
HD Request # 14 | Intraday data download complete for QMZ19_FUT_NYMEX. Unique request ID: 12 | 2019-11-01 09:25:02.568
Removed historical data download ID 12 | 2019-11-01 09:25:02.568
Real-time Intraday chart data file updates started for QMZ19_FUT_NYMEX | 2019-11-01 09:25:02.568
Opened cached Intraday file: C:\SierraChart\Data\QMZ19_FUT_NYMEX.scid | 2019-11-01 09:25:02.568
Intraday chart data file opened for QMZ19_FUT_NYMEX | 2019-11-01 09:25:02.568
Triggering next historical data download in queue. | 2019-11-01 09:25:02.568
Socket (3) | Socket gracefully closed by remote side. | 2019-11-01 09:25:02.641
Socket (3) | Closed. | 2019-11-01 09:25:02.641
SC Futures Order Routing/Data | Performing periodic download of Intraday data for open Intraday charts not receiving real-time data | 2019-11-01 09:45:01.370
Added Intraday data request for CLZ19_FUT_NYMEX to the queue. | 2019-11-01 09:45:01.370
Intraday data recording state for symbol CLZ19_FUT_NYMEX is set to download 'Pending'. | 2019-11-01 09:45:01.370
Triggering next historical data download in queue. | 2019-11-01 09:45:01.370
Added Intraday data request for QMZ19_FUT_NYMEX to the queue. | 2019-11-01 09:45:01.370
Intraday data recording state for symbol QMZ19_FUT_NYMEX is set to download 'Pending'. | 2019-11-01 09:45:01.370
HD Request # 15 | Downloading Intraday chart data for CLZ19_FUT_NYMEX to the file CLZ19_FUT_NYMEX.scid. Service: nymex | 2019-11-01 09:45:01.370
HD Request # 15 | Download start date-time: 2019-11-01 09:15:03.000 | 2019-11-01 09:45:01.370
HD Request # 15 | Using server: exchangehistdata1.sierracharts.com port 10149 | 2019-11-01 09:45:01.371
Socket (1) | Creating socket. | 2019-11-01 09:45:01.372
Socket (1) | Connecting to IP: 8.18.161.135. | 2019-11-01 09:45:01.372
HD Request # 15 | Setting DTC encoding to Binary VLS | 2019-11-01 09:45:01.577
HD Request # 15 | Sending historical data logon request message. | 2019-11-01 09:45:01.577
HD Request # 15 | Requesting Intraday data. Start date-time: 2019-11-01 09:15:03. Record interval: 1. Symbol: CLZ19 | 2019-11-01 09:45:01.676
HD Request # 15 | Decompressing data. | 2019-11-01 09:45:02.009
HD Request # 15 | Receiving Intraday data for CLZ19_FUT_NYMEX starting at 2019-11-01 09:15:03 | 2019-11-01 09:45:02.605
HD Request # 15 | Timestamp of first Intraday data file record written: 2019-11-01 09:15:03 | 2019-11-01 09:45:02.605
Socket (1) | Shutdown started. Waiting for graceful close. | 2019-11-01 09:45:02.605
Historical data download thread signaled to stop. | 2019-11-01 09:45:02.615
HD Request # 15 | Received 1014 records from 2019-11-01 09:15:03.000 to 2019-11-01 09:35:03.000 (20.0 minutes) and wrote 1014 records for CLZ19_FUT_NYMEX | 2019-11-01 09:45:02.616
HD Request # 15 | Completion time: 1s | 2019-11-01 09:45:02.621
HD Request # 15 | Intraday data download complete for CLZ19_FUT_NYMEX. Unique request ID: 13 | 2019-11-01 09:45:02.621
Removed historical data download ID 13 | 2019-11-01 09:45:02.621
Real-time Intraday chart data file updates started for CLZ19_FUT_NYMEX | 2019-11-01 09:45:02.621
Opened cached Intraday file: C:\SierraChart\Data\CLZ19_FUT_NYMEX.scid | 2019-11-01 09:45:02.621
Intraday chart data file opened for CLZ19_FUT_NYMEX | 2019-11-01 09:45:02.621
Triggering next historical data download in queue. | 2019-11-01 09:45:02.621
HD Request # 16 | Downloading Intraday chart data for QMZ19_FUT_NYMEX to the file QMZ19_FUT_NYMEX.scid. Service: nymex | 2019-11-01 09:45:02.621
HD Request # 16 | Download start date-time: 2019-11-01 09:15:03.000 | 2019-11-01 09:45:02.622
HD Request # 16 | Using server: exchangehistdata2.sierracharts.com port 10150 | 2019-11-01 09:45:02.622
Socket (3) | Creating socket. | 2019-11-01 09:45:02.623
Socket (3) | Connecting to IP: 8.18.161.133. | 2019-11-01 09:45:02.623
Socket (1) | Socket gracefully closed by remote side. | 2019-11-01 09:45:02.712
Socket (1) | Closed. | 2019-11-01 09:45:02.712
HD Request # 16 | Setting DTC encoding to Binary VLS | 2019-11-01 09:45:02.842
HD Request # 16 | Sending historical data logon request message. | 2019-11-01 09:45:02.842
HD Request # 16 | Requesting Intraday data. Start date-time: 2019-11-01 09:15:03. Record interval: 1. Symbol: QMZ19 | 2019-11-01 09:45:02.947
HD Request # 16 | Decompressing data. | 2019-11-01 09:45:03.053
HD Request # 16 | Receiving Intraday data for QMZ19_FUT_NYMEX starting at 2019-11-01 09:15:03 | 2019-11-01 09:45:03.053
HD Request # 16 | Timestamp of first Intraday data file record written: 2019-11-01 09:15:03 | 2019-11-01 09:45:03.054
Socket (3) | Shutdown started. Waiting for graceful close. | 2019-11-01 09:45:03.054
Historical data download thread signaled to stop. | 2019-11-01 09:45:03.086
HD Request # 16 | Received 234 records from 2019-11-01 09:15:03.000 to 2019-11-01 09:34:53.000 (19.8 minutes) and wrote 234 records for QMZ19_FUT_NYMEX | 2019-11-01 09:45:03.086
HD Request # 16 | Completion time: 1s | 2019-11-01 09:45:03.090
HD Request # 16 | Intraday data download complete for QMZ19_FUT_NYMEX. Unique request ID: 14 | 2019-11-01 09:45:03.090
Removed historical data download ID 14 | 2019-11-01 09:45:03.090
Real-time Intraday chart data file updates started for QMZ19_FUT_NYMEX | 2019-11-01 09:45:03.090
Opened cached Intraday file: C:\SierraChart\Data\QMZ19_FUT_NYMEX.scid | 2019-11-01 09:45:03.091
Intraday chart data file opened for QMZ19_FUT_NYMEX | 2019-11-01 09:45:03.091
Triggering next historical data download in queue. | 2019-11-01 09:45:03.091
Socket (3) | Socket gracefully closed by remote side. | 2019-11-01 09:45:03.156
Socket (3) | Closed. | 2019-11-01 09:45:03.156
SC Futures Order Routing/Data | Performing periodic download of Intraday data for open Intraday charts not receiving real-time data | 2019-11-01 10:05:01.369
Added Intraday data request for CLZ19_FUT_NYMEX to the queue. | 2019-11-01 10:05:01.370
Intraday data recording state for symbol CLZ19_FUT_NYMEX is set to download 'Pending'. | 2019-11-01 10:05:01.370
Triggering next historical data download in queue. | 2019-11-01 10:05:01.370
Added Intraday data request for QMZ19_FUT_NYMEX to the queue. | 2019-11-01 10:05:01.370
Intraday data recording state for symbol QMZ19_FUT_NYMEX is set to download 'Pending'. | 2019-11-01 10:05:01.370
HD Request # 17 | Downloading Intraday chart data for CLZ19_FUT_NYMEX to the file CLZ19_FUT_NYMEX.scid. Service: nymex | 2019-11-01 10:05:01.370
HD Request # 17 | Download start date-time: 2019-11-01 09:35:03.000 | 2019-11-01 10:05:01.370
HD Request # 17 | Using server: exchangehistdata1.sierracharts.com port 10149 | 2019-11-01 10:05:01.370
Socket (1) | Creating socket. | 2019-11-01 10:05:01.371
Socket (1) | Connecting to IP: 8.18.161.135. | 2019-11-01 10:05:01.372
HD Request # 17 | Setting DTC encoding to Binary VLS | 2019-11-01 10:05:01.586
HD Request # 17 | Sending historical data logon request message. | 2019-11-01 10:05:01.586
HD Request # 17 | Requesting Intraday data. Start date-time: 2019-11-01 09:35:03. Record interval: 1. Symbol: CLZ19 | 2019-11-01 10:05:01.690
HD Request # 17 | Decompressing data. | 2019-11-01 10:05:01.920
HD Request # 17 | Receiving Intraday data for CLZ19_FUT_NYMEX starting at 2019-11-01 09:35:03 | 2019-11-01 10:05:02.195
HD Request # 17 | Timestamp of first Intraday data file record written: 2019-11-01 09:35:03 | 2019-11-01 10:05:02.195
Socket (1) | Shutdown started. Waiting for graceful close. | 2019-11-01 10:05:02.195
Historical data download thread signaled to stop. | 2019-11-01 10:05:02.211
HD Request # 17 | Received 1001 records from 2019-11-01 09:35:03.000 to 2019-11-01 09:55:03.000 (20.0 minutes) and wrote 1001 records for CLZ19_FUT_NYMEX | 2019-11-01 10:05:02.212
HD Request # 17 | Completion time: 1s | 2019-11-01 10:05:02.217
HD Request # 17 | Intraday data download complete for CLZ19_FUT_NYMEX. Unique request ID: 15 | 2019-11-01 10:05:02.217
Removed historical data download ID 15 | 2019-11-01 10:05:02.217
Real-time Intraday chart data file updates started for CLZ19_FUT_NYMEX | 2019-11-01 10:05:02.217
Opened cached Intraday file: C:\SierraChart\Data\CLZ19_FUT_NYMEX.scid | 2019-11-01 10:05:02.217
Intraday chart data file opened for CLZ19_FUT_NYMEX | 2019-11-01 10:05:02.217
Triggering next historical data download in queue. | 2019-11-01 10:05:02.217
HD Request # 18 | Downloading Intraday chart data for QMZ19_FUT_NYMEX to the file QMZ19_FUT_NYMEX.scid. Service: nymex | 2019-11-01 10:05:02.218
HD Request # 18 | Download start date-time: 2019-11-01 09:34:53.000 | 2019-11-01 10:05:02.218
HD Request # 18 | Using server: exchangehistdata2.sierracharts.com port 10150 | 2019-11-01 10:05:02.218
Socket (3) | Creating socket. | 2019-11-01 10:05:02.219
Socket (3) | Connecting to IP: 8.18.161.133. | 2019-11-01 10:05:02.219
Socket (1) | Socket gracefully closed by remote side. | 2019-11-01 10:05:02.299
Socket (1) | Closed. | 2019-11-01 10:05:02.299
HD Request # 18 | Setting DTC encoding to Binary VLS | 2019-11-01 10:05:02.436
HD Request # 18 | Sending historical data logon request message. | 2019-11-01 10:05:02.436
HD Request # 18 | Requesting Intraday data. Start date-time: 2019-11-01 09:34:53. Record interval: 1. Symbol: QMZ19 | 2019-11-01 10:05:02.540
HD Request # 18 | Decompressing data. | 2019-11-01 10:05:02.645
HD Request # 18 | Receiving Intraday data for QMZ19_FUT_NYMEX starting at 2019-11-01 09:34:53 | 2019-11-01 10:05:02.645
HD Request # 18 | Timestamp of first Intraday data file record written: 2019-11-01 09:34:53 | 2019-11-01 10:05:02.646
Socket (3) | Shutdown started. Waiting for graceful close. | 2019-11-01 10:05:02.648
Historical data download thread signaled to stop. | 2019-11-01 10:05:02.662
HD Request # 18 | Received 250 records from 2019-11-01 09:34:53.000 to 2019-11-01 09:54:58.000 (20.1 minutes) and wrote 250 records for QMZ19_FUT_NYMEX | 2019-11-01 10:05:02.662
HD Request # 18 | Completion time: 0s | 2019-11-01 10:05:02.666
HD Request # 18 | Intraday data download complete for QMZ19_FUT_NYMEX. Unique request ID: 16 | 2019-11-01 10:05:02.666
Removed historical data download ID 16 | 2019-11-01 10:05:02.666
Real-time Intraday chart data file updates started for QMZ19_FUT_NYMEX | 2019-11-01 10:05:02.666
Opened cached Intraday file: C:\SierraChart\Data\QMZ19_FUT_NYMEX.scid | 2019-11-01 10:05:02.666
Intraday chart data file opened for QMZ19_FUT_NYMEX | 2019-11-01 10:05:02.666
Triggering next historical data download in queue. | 2019-11-01 10:05:02.666
Socket (3) | Socket gracefully closed by remote side. | 2019-11-01 10:05:02.753
Socket (3) | Closed. | 2019-11-01 10:05:02.753
SC Futures Order Routing/Data | Performing periodic download of Intraday data for open Intraday charts not receiving real-time data | 2019-11-01 10:25:01.358
Added Intraday data request for CLZ19_FUT_NYMEX to the queue. | 2019-11-01 10:25:01.358
Intraday data recording state for symbol CLZ19_FUT_NYMEX is set to download 'Pending'. | 2019-11-01 10:25:01.358
Triggering next historical data download in queue. | 2019-11-01 10:25:01.358
Added Intraday data request for QMZ19_FUT_NYMEX to the queue. | 2019-11-01 10:25:01.358
Intraday data recording state for symbol QMZ19_FUT_NYMEX is set to download 'Pending'. | 2019-11-01 10:25:01.358
HD Request # 19 | Downloading Intraday chart data for CLZ19_FUT_NYMEX to the file CLZ19_FUT_NYMEX.scid. Service: nymex | 2019-11-01 10:25:01.358
HD Request # 19 | Download start date-time: 2019-11-01 09:55:03.000 | 2019-11-01 10:25:01.359
HD Request # 19 | Using server: exchangehistdata1.sierracharts.com port 10149 | 2019-11-01 10:25:01.359
Socket (1) | Creating socket. | 2019-11-01 10:25:01.360
Socket (1) | Connecting to IP: 8.18.161.135. | 2019-11-01 10:25:01.360
HD Request # 19 | Setting DTC encoding to Binary VLS | 2019-11-01 10:25:01.565
HD Request # 19 | Sending historical data logon request message. | 2019-11-01 10:25:01.565
HD Request # 19 | Requesting Intraday data. Start date-time: 2019-11-01 09:55:03. Record interval: 1. Symbol: CLZ19 | 2019-11-01 10:25:01.662
HD Request # 19 | Decompressing data. | 2019-11-01 10:25:01.762
HD Request # 19 | Receiving Intraday data for CLZ19_FUT_NYMEX starting at 2019-11-01 09:55:03 | 2019-11-01 10:25:01.867
HD Request # 19 | Timestamp of first Intraday data file record written: 2019-11-01 09:55:03 | 2019-11-01 10:25:01.867
Socket (1) | Shutdown started. Waiting for graceful close. | 2019-11-01 10:25:01.867
Historical data download thread signaled to stop. | 2019-11-01 10:25:01.869
HD Request # 19 | Received 911 records from 2019-11-01 09:55:03.000 to 2019-11-01 10:15:02.000 (20.0 minutes) and wrote 911 records for CLZ19_FUT_NYMEX | 2019-11-01 10:25:01.869
HD Request # 19 | Completion time: 0s | 2019-11-01 10:25:01.875
HD Request # 19 | Intraday data download complete for CLZ19_FUT_NYMEX. Unique request ID: 17 | 2019-11-01 10:25:01.875
Removed historical data download ID 17 | 2019-11-01 10:25:01.875
Real-time Intraday chart data file updates started for CLZ19_FUT_NYMEX | 2019-11-01 10:25:01.875
Opened cached Intraday file: C:\SierraChart\Data\CLZ19_FUT_NYMEX.scid | 2019-11-01 10:25:01.875
Intraday chart data file opened for CLZ19_FUT_NYMEX | 2019-11-01 10:25:01.875
Triggering next historical data download in queue. | 2019-11-01 10:25:01.875
HD Request # 20 | Downloading Intraday chart data for QMZ19_FUT_NYMEX to the file QMZ19_FUT_NYMEX.scid. Service: nymex | 2019-11-01 10:25:01.875
HD Request # 20 | Download start date-time: 2019-11-01 09:54:58.000 | 2019-11-01 10:25:01.875
HD Request # 20 | Using server: exchangehistdata2.sierracharts.com port 10150 | 2019-11-01 10:25:01.875
Socket (3) | Creating socket. | 2019-11-01 10:25:01.876
Socket (3) | Connecting to IP: 8.18.161.133. | 2019-11-01 10:25:01.876
Socket (1) | Socket gracefully closed by remote side. | 2019-11-01 10:25:01.968
Socket (1) | Closed. | 2019-11-01 10:25:01.968
HD Request # 20 | Setting DTC encoding to Binary VLS | 2019-11-01 10:25:02.091
HD Request # 20 | Sending historical data logon request message. | 2019-11-01 10:25:02.091
HD Request # 20 | Requesting Intraday data. Start date-time: 2019-11-01 09:54:58. Record interval: 1. Symbol: QMZ19 | 2019-11-01 10:25:02.197
HD Request # 20 | Decompressing data. | 2019-11-01 10:25:02.302
HD Request # 20 | Receiving Intraday data for QMZ19_FUT_NYMEX starting at 2019-11-01 09:54:58 | 2019-11-01 10:25:02.305
HD Request # 20 | Timestamp of first Intraday data file record written: 2019-11-01 09:54:58 | 2019-11-01 10:25:02.305
Socket (3) | Shutdown started. Waiting for graceful close. | 2019-11-01 10:25:02.305
Historical data download thread signaled to stop. | 2019-11-01 10:25:02.316
HD Request # 20 | Received 219 records from 2019-11-01 09:54:58.000 to 2019-11-01 10:15:00.000 (20.0 minutes) and wrote 219 records for QMZ19_FUT_NYMEX | 2019-11-01 10:25:02.317
HD Request # 20 | Completion time: 0s | 2019-11-01 10:25:02.321
HD Request # 20 | Intraday data download complete for QMZ19_FUT_NYMEX. Unique request ID: 18 | 2019-11-01 10:25:02.321
Removed historical data download ID 18 | 2019-11-01 10:25:02.321
Real-time Intraday chart data file updates started for QMZ19_FUT_NYMEX | 2019-11-01 10:25:02.321
Opened cached Intraday file: C:\SierraChart\Data\QMZ19_FUT_NYMEX.scid | 2019-11-01 10:25:02.321
Intraday chart data file opened for QMZ19_FUT_NYMEX | 2019-11-01 10:25:02.321
Triggering next historical data download in queue. | 2019-11-01 10:25:02.321
Socket (3) | Socket gracefully closed by remote side. | 2019-11-01 10:25:02.410
Socket (3) | Closed. | 2019-11-01 10:25:02.410
SC Futures Order Routing/Data | Performing periodic download of Intraday data for open Intraday charts not receiving real-time data | 2019-11-01 10:45:01.362
Added Intraday data request for CLZ19_FUT_NYMEX to the queue. | 2019-11-01 10:45:01.362
Intraday data recording state for symbol CLZ19_FUT_NYMEX is set to download 'Pending'. | 2019-11-01 10:45:01.362
Triggering next historical data download in queue. | 2019-11-01 10:45:01.362
Added Intraday data request for QMZ19_FUT_NYMEX to the queue. | 2019-11-01 10:45:01.362
Intraday data recording state for symbol QMZ19_FUT_NYMEX is set to download 'Pending'. | 2019-11-01 10:45:01.362
HD Request # 21 | Downloading Intraday chart data for CLZ19_FUT_NYMEX to the file CLZ19_FUT_NYMEX.scid. Service: nymex | 2019-11-01 10:45:01.362
HD Request # 21 | Download start date-time: 2019-11-01 10:15:02.000 | 2019-11-01 10:45:01.363
HD Request # 21 | Using server: exchangehistdata1.sierracharts.com port 10149 | 2019-11-01 10:45:01.363
Socket (1) | Creating socket. | 2019-11-01 10:45:01.364
Socket (1) | Connecting to IP: 8.18.161.135. | 2019-11-01 10:45:01.364
HD Request # 21 | Setting DTC encoding to Binary VLS | 2019-11-01 10:45:01.569
HD Request # 21 | Sending historical data logon request message. | 2019-11-01 10:45:01.569
HD Request # 21 | Requesting Intraday data. Start date-time: 2019-11-01 10:15:02. Record interval: 1. Symbol: CLZ19 | 2019-11-01 10:45:01.668
HD Request # 21 | Decompressing data. | 2019-11-01 10:45:01.891
HD Request # 21 | Receiving Intraday data for CLZ19_FUT_NYMEX starting at 2019-11-01 10:15:02 | 2019-11-01 10:45:02.056
HD Request # 21 | Timestamp of first Intraday data file record written: 2019-11-01 10:15:02 | 2019-11-01 10:45:02.056
Historical data download thread signaled to stop. | 2019-11-01 10:45:02.056
Socket (1) | Shutdown started. Waiting for graceful close. | 2019-11-01 10:45:02.056
HD Request # 21 | Received 869 records from 2019-11-01 10:15:02.000 to 2019-11-01 10:35:03.000 (20.0 minutes) and wrote 869 records for CLZ19_FUT_NYMEX | 2019-11-01 10:45:02.057
HD Request # 21 | Completion time: 0s | 2019-11-01 10:45:02.062
HD Request # 21 | Intraday data download complete for CLZ19_FUT_NYMEX. Unique request ID: 19 | 2019-11-01 10:45:02.062
Removed historical data download ID 19 | 2019-11-01 10:45:02.062
Real-time Intraday chart data file updates started for CLZ19_FUT_NYMEX | 2019-11-01 10:45:02.062
Opened cached Intraday file: C:\SierraChart\Data\CLZ19_FUT_NYMEX.scid | 2019-11-01 10:45:02.062
Intraday chart data file opened for CLZ19_FUT_NYMEX | 2019-11-01 10:45:02.062
Triggering next historical data download in queue. | 2019-11-01 10:45:02.062
HD Request # 22 | Downloading Intraday chart data for QMZ19_FUT_NYMEX to the file QMZ19_FUT_NYMEX.scid. Service: nymex | 2019-11-01 10:45:02.062
HD Request # 22 | Download start date-time: 2019-11-01 10:15:00.000 | 2019-11-01 10:45:02.063
HD Request # 22 | Using server: exchangehistdata2.sierracharts.com port 10150 | 2019-11-01 10:45:02.063
Socket (3) | Creating socket. | 2019-11-01 10:45:02.064
Socket (3) | Connecting to IP: 8.18.161.133. | 2019-11-01 10:45:02.064
Socket (1) | Socket gracefully closed by remote side. | 2019-11-01 10:45:02.157
Socket (1) | Closed. | 2019-11-01 10:45:02.158
HD Request # 22 | Setting DTC encoding to Binary VLS | 2019-11-01 10:45:02.284
HD Request # 22 | Sending historical data logon request message. | 2019-11-01 10:45:02.284
HD Request # 22 | Requesting Intraday data. Start date-time: 2019-11-01 10:15:00. Record interval: 1. Symbol: QMZ19 | 2019-11-01 10:45:02.388
HD Request # 22 | Decompressing data. | 2019-11-01 10:45:02.492
HD Request # 22 | Receiving Intraday data for QMZ19_FUT_NYMEX starting at 2019-11-01 10:15:00 | 2019-11-01 10:45:02.492
HD Request # 22 | Timestamp of first Intraday data file record written: 2019-11-01 10:15:00 | 2019-11-01 10:45:02.493
Socket (3) | Shutdown started. Waiting for graceful close. | 2019-11-01 10:45:02.493
Historical data download thread signaled to stop. | 2019-11-01 10:45:02.518
HD Request # 22 | Received 195 records from 2019-11-01 10:15:00.000 to 2019-11-01 10:34:58.000 (20.0 minutes) and wrote 195 records for QMZ19_FUT_NYMEX | 2019-11-01 10:45:02.518
HD Request # 22 | Completion time: 0s | 2019-11-01 10:45:02.522
HD Request # 22 | Intraday data download complete for QMZ19_FUT_NYMEX. Unique request ID: 20 | 2019-11-01 10:45:02.522
Removed historical data download ID 20 | 2019-11-01 10:45:02.522
Real-time Intraday chart data file updates started for QMZ19_FUT_NYMEX | 2019-11-01 10:45:02.522
Opened cached Intraday file: C:\SierraChart\Data\QMZ19_FUT_NYMEX.scid | 2019-11-01 10:45:02.522
Intraday chart data file opened for QMZ19_FUT_NYMEX | 2019-11-01 10:45:02.522
Triggering next historical data download in queue. | 2019-11-01 10:45:02.522
Socket (3) | Socket gracefully closed by remote side. | 2019-11-01 10:45:02.596
Socket (3) | Closed. | 2019-11-01 10:45:02.596
SC Futures Order Routing/Data | Performing periodic download of Intraday data for open Intraday charts not receiving real-time data | 2019-11-01 11:05:01.359
Added Intraday data request for CLZ19_FUT_NYMEX to the queue. | 2019-11-01 11:05:01.359
Intraday data recording state for symbol CLZ19_FUT_NYMEX is set to download 'Pending'. | 2019-11-01 11:05:01.359
Triggering next historical data download in queue. | 2019-11-01 11:05:01.360
Added Intraday data request for QMZ19_FUT_NYMEX to the queue. | 2019-11-01 11:05:01.360
Intraday data recording state for symbol QMZ19_FUT_NYMEX is set to download 'Pending'. | 2019-11-01 11:05:01.360
HD Request # 23 | Downloading Intraday chart data for CLZ19_FUT_NYMEX to the file CLZ19_FUT_NYMEX.scid. Service: nymex | 2019-11-01 11:05:01.360
HD Request # 23 | Download start date-time: 2019-11-01 10:35:03.000 | 2019-11-01 11:05:01.360
HD Request # 23 | Using server: exchangehistdata1.sierracharts.com port 10149 | 2019-11-01 11:05:01.360
Socket (1) | Creating socket. | 2019-11-01 11:05:01.361
Socket (1) | Connecting to IP: 8.18.161.135. | 2019-11-01 11:05:01.362
HD Request # 23 | Setting DTC encoding to Binary VLS | 2019-11-01 11:05:01.566
HD Request # 23 | Sending historical data logon request message. | 2019-11-01 11:05:01.566
HD Request # 23 | Requesting Intraday data. Start date-time: 2019-11-01 10:35:03. Record interval: 1. Symbol: CLZ19 | 2019-11-01 11:05:01.664
HD Request # 23 | Decompressing data. | 2019-11-01 11:05:01.762
HD Request # 23 | Receiving Intraday data for CLZ19_FUT_NYMEX starting at 2019-11-01 10:35:03 | 2019-11-01 11:05:01.861
HD Request # 23 | Timestamp of first Intraday data file record written: 2019-11-01 10:35:03 | 2019-11-01 11:05:01.862
Socket (1) | Shutdown started. Waiting for graceful close. | 2019-11-01 11:05:01.862
Historical data download thread signaled to stop. | 2019-11-01 11:05:01.864
HD Request # 23 | Received 909 records from 2019-11-01 10:35:03.000 to 2019-11-01 10:55:03.000 (20.0 minutes) and wrote 909 records for CLZ19_FUT_NYMEX | 2019-11-01 11:05:01.864
HD Request # 23 | Completion time: 0s | 2019-11-01 11:05:01.870
HD Request # 23 | Intraday data download complete for CLZ19_FUT_NYMEX. Unique request ID: 21 | 2019-11-01 11:05:01.870
Removed historical data download ID 21 | 2019-11-01 11:05:01.870
Real-time Intraday chart data file updates started for CLZ19_FUT_NYMEX | 2019-11-01 11:05:01.870
Opened cached Intraday file: C:\SierraChart\Data\CLZ19_FUT_NYMEX.scid | 2019-11-01 11:05:01.870
Intraday chart data file opened for CLZ19_FUT_NYMEX | 2019-11-01 11:05:01.870
Triggering next historical data download in queue. | 2019-11-01 11:05:01.870
HD Request # 24 | Downloading Intraday chart data for QMZ19_FUT_NYMEX to the file QMZ19_FUT_NYMEX.scid. Service: nymex | 2019-11-01 11:05:01.870
HD Request # 24 | Download start date-time: 2019-11-01 10:34:58.000 | 2019-11-01 11:05:01.870
HD Request # 24 | Using server: exchangehistdata2.sierracharts.com port 10150 | 2019-11-01 11:05:01.870
Socket (3) | Creating socket. | 2019-11-01 11:05:01.871
Socket (3) | Connecting to IP: 8.18.161.133. | 2019-11-01 11:05:01.871
Socket (1) | Socket gracefully closed by remote side. | 2019-11-01 11:05:01.962
Socket (1) | Closed. | 2019-11-01 11:05:01.962
HD Request # 24 | Setting DTC encoding to Binary VLS | 2019-11-01 11:05:02.079
HD Request # 24 | Sending historical data logon request message. | 2019-11-01 11:05:02.079
HD Request # 24 | Requesting Intraday data. Start date-time: 2019-11-01 10:34:58. Record interval: 1. Symbol: QMZ19 | 2019-11-01 11:05:02.181
HD Request # 24 | Decompressing data. | 2019-11-01 11:05:02.280
HD Request # 24 | Receiving Intraday data for QMZ19_FUT_NYMEX starting at 2019-11-01 10:34:58 | 2019-11-01 11:05:02.280
HD Request # 24 | Timestamp of first Intraday data file record written: 2019-11-01 10:34:58 | 2019-11-01 11:05:02.280
Socket (3) | Shutdown started. Waiting for graceful close. | 2019-11-01 11:05:02.280
Historical data download thread signaled to stop. | 2019-11-01 11:05:02.300
HD Request # 24 | Received 178 records from 2019-11-01 10:34:58.000 to 2019-11-01 10:54:15.000 (19.3 minutes) and wrote 178 records for QMZ19_FUT_NYMEX | 2019-11-01 11:05:02.300
HD Request # 24 | Completion time: 1s | 2019-11-01 11:05:02.304
HD Request # 24 | Intraday data download complete for QMZ19_FUT_NYMEX. Unique request ID: 22 | 2019-11-01 11:05:02.304
Removed historical data download ID 22 | 2019-11-01 11:05:02.304
Real-time Intraday chart data file updates started for QMZ19_FUT_NYMEX | 2019-11-01 11:05:02.304
Opened cached Intraday file: C:\SierraChart\Data\QMZ19_FUT_NYMEX.scid | 2019-11-01 11:05:02.304
Intraday chart data file opened for QMZ19_FUT_NYMEX | 2019-11-01 11:05:02.304
Triggering next historical data download in queue. | 2019-11-01 11:05:02.304
Socket (3) | Socket gracefully closed by remote side. | 2019-11-01 11:05:02.383
Socket (3) | Closed. | 2019-11-01 11:05:02.383
[2019-11-01 16:42:49]
John - SC Support - Posts: 37656
You did not have enough funds in your Services Balance to pay for the Denali Exchange Data Feed for the month of November. You need to add funds to your account and then reactivate the Denali Exchange Data feed. You can add funds at this link:
https://www.sierrachart.com/UserControlPanel.php?page=AddAccountCredit
Then go to the following page to reactivate the Denali Exchange Data Feed:
https://www.sierrachart.com/UserControlPanel.php?page=RecurringServices
[2019-11-01 16:54:16]
Rene Velazquez - Posts: 9
I just paid $62 on the 23rd of October. How much do I need to pay per month for the services selected?
[2019-11-01 17:21:48]
- $26 USD per month for Sierra Chart software at Package 3.
- $20 USD per month for the Denali Exchange Data Feed.
- $15.75 USD per month for the CME Group with Market Depth exchange.
Total per month = $61.75 USD
But, you also are using the Sierra Chart Order Routing Service, which has a $0.10 USD charge per order.
You can see the full list of transactions for your account here:
https://www.sierrachart.com/UserControlPanel.php?page=TransactionLog
[2019-11-01 17:41:29]
Thanks for the response. Question, I tried to add the Market Depth Historical Graph, under studies, but it couldn't be done. Do I need to pay extra for that service?
regards
Rene
[2019-11-01 18:03:45]
I just made the payment, and still see the same issue. I restarted SC, a couple of times. Do you know how long does it take for the service to be restablished?
[2019-11-01 18:14:10]
With respect to Post #8:
You did not re-activate the Exchange itself. We went ahead and activated it for you now. So you should be receiving Real-Time data now. If you are not, then exit Sierra Chart and start Sierra Chart again.
With respect to Post #7:
The Market Depth Historical Graph is only available if you are on Package 5 of Sierra Chart. You are on Package 3. You will find the information on the differences between the packages here:
Description of Service Packages and Pricing: Packages
You can switch between the packages without having to pay additional fees, just the end-time will change depending on which way you are changing your package.
