Date/Time: Mon, 03 Feb 2025 06:58:59 +0000
Chart Value for Tools - bug???
View Count: 626
[2019-11-01 13:14:54]
nicktrader - Posts: 734
As you can see in the pic the Chart Value for Tools gives back Information you do not need (ID:1, ID:2 etc).
I am running vers. 2006
Date Time Of Last Edit: 2019-11-01 13:15:45
imageChart Value forTools.png / V - Attached On 2019-11-01 13:14:32 UTC - Size: 13.63 KB - 237 views
[2019-11-01 13:15:40]
We will look that over.
[2019-11-03 14:49:19]
Just to inform you.
The subgraphs settings only for ID 4 (BRan) is different to the other Studies. All others are switch off.
imageStudy Subgraphs Settings.png / V - Attached On 2019-11-03 14:45:57 UTC - Size: 22.68 KB - 240 views
[2019-11-04 03:24:28]
Update to the latest revision of 2007.
[2019-11-04 08:56:13]
On my 2nd PC I am running 2007 too and all is fine. I have to check it.
