Date/Time: Sun, 05 May 2024 07:19:32 +0000
Calling/Copying Drawings from Another Instance
View Count: 1231
[2019-10-31 21:56:48] |
User600284 - Posts: 9 |
Hi, As the title says is there a way to copy drawings from another instance for the same symbol? Thank you. |
[2019-11-01 14:49:31] |
John - SC Support - Posts: 31362 |
You can not copy drawings from another instance. Each instance is independent. You can copy drawings between charts and chartbooks within the same instance. Refer to the documentation here: Chart Settings: Copy Chart Drawings from Chart #'s (Chart >> Chart Settings >> Chart Drawings menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
