Date/Time: Fri, 03 May 2024 11:51:56 +0000
issue to download update version software
View Count: 486
[2019-10-31 18:12:38] |
User657945 - Posts: 226 |
I'm having trouble to download new version I'm now at 1983 and I try to download current version or specific version 2003 but the process stop working, it tooks 3 times to download it but only after 5 minutes the download has ended. I sent log to support from the log button. thx |
[2019-10-31 18:28:49] |
We recommend trying again later. Instructions: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
