Date/Time: Fri, 03 May 2024 08:40:16 +0000
numbers bars
View Count: 823
[2019-10-31 16:24:25] |
User318521 - Posts: 45 |
is there any way to add a transparency setting for the volume profile background on the numbers bars study. its kinda hard to read the text and see buy and sell imbalances with regular colors. thanks |
[2019-10-31 20:14:35] |
No, it is not possible to set a transparency, and doing so would impact performance greatly. You have many different options for setting both the colors of the background and the colors of the numbers. You just need to find a combination that will work for your needs. Refer to this particular setting: Numbers Bars: Default Text Color Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
