Date/Time: Fri, 03 May 2024 10:22:50 +0000
tools => draw volume profile
View Count: 693
[2019-10-31 15:57:24] |
User630795 - Posts: 86 |
i followed all the instruction regarding this tool but it does nothing. why is that?
[2019-10-31 20:27:23] |
The ability to use Draw Volume Profile is only available on Package 5. This is stated clearly in step #1 of the documentation here: Volume By Price Study: Tool Usage You are on Package 3, so this is why you are not getting anything. To change to Package 5, notify AMP and they can change your package. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
