Date/Time: Sat, 04 May 2024 23:57:10 +0000
Changed accounts and want to set up with new account
View Count: 431
[2019-10-31 12:48:54] |
Jim Ashley - Posts: 2 |
Do I just enter credentials? Will it keep all of my chart settings? Thanks
[2019-11-01 12:44:19] |
Yes everything remains the same. When you say you changed accounts, are you referring to a different trading service or are you referring to a different Sierra Chart account?
