Date/Time: Sun, 05 May 2024 02:41:17 +0000
Keeping the current price displayed on the scale when scrolling
View Count: 805
[2019-10-31 06:30:44] |
samuelson - Posts: 9 |
How do I display the current market price on the right-side scale when I scroll backward? It only shows the last price in the current view. I'd like to be able to see both for comparison. https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=32713 Date Time Of Last Edit: 2019-10-31 09:44:25
Screen Shot 2019-10-31 at 02.24.34.png / V - Attached On 2019-10-31 06:24:52 UTC - Size: 14.49 KB - 357 views |
[2019-10-31 18:53:01] |
Use the Current Price Line study and set the Subgraph Draw Style to Subgraph Name and Value Labels Only, then turn on the Value Label for the Right Side Scale. Refer to the following for this draw style: Chart Studies: Subgraph Name and Value Labels Only (ACSIL: DRAWSTYLE_SUBGRAPH_NAME_AND_VALUE_LABELS_ONLY) And refer to the documentation for the Current Price Line here: Current Price Line Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-10-31 18:53:50
[2019-11-01 07:58:28] |
I tried it, but the line only spans across the last day and disappears when I scroll back in time. I need the current price to alway be visible as I scroll back in time. https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=32741 |
Screen Shot 2019-11-01 at 03.53.07.png / V - Attached On 2019-11-01 07:54:00 UTC - Size: 22.45 KB - 312 views |
[2019-11-01 15:06:20] |
John - SC Support - Posts: 31362 |
Increase the setting for Number of Bars to Display On in the Current Price Line study. Enter a value that would cover the number of bars in your chart.
[2019-11-01 17:09:21] |
Post #4 is not recommended because it is inefficient.
[2019-11-01 17:21:09] |
That's what I thought. What do you recommend? It's helpful if I can see both values for comparison. |
