Date/Time: Fri, 03 May 2024 05:48:34 +0000
Can't see more than 1 month of volume data
View Count: 571
[2019-10-31 01:10:35] |
User273624 - Posts: 10 |
I can see bar data, but my volume study stops displaying data after 1 month worth of bars. How can I increase this to 1 year?
[2019-10-31 06:22:20] |
samuelson - Posts: 9 |
Right-click on the chart then click on Chart Settings, then set "Days to Load" to which ever number you like. Setting to zero loads all the data, but for performance best if you set a number of days.
[2019-10-31 07:52:25] |
Refer to this section here: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Downloading/Viewing More Historical Intraday Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
