Date/Time: Mon, 03 Feb 2025 04:58:45 +0000
Deleting/resetting New Instance
View Count: 741
[2019-10-31 01:00:07]
User34124 - Posts: 279
Can't find documentation on this. Deleted the folders associated, and will go to File, New Instance again in hope of updating and refreshing the New Instances with Master data. Is this the correct way?
[2019-11-01 15:42:33]
Linked to this may I know exactly what you mean by having Sierra Charts on it's own 'dedicated' SSD?
Is the best configuration therefore to have two HDs in a computer? Booting from one for trading or one for everything else? The Sierra one should have Windows and Sierra charts on it and nothing else? Not even browser?
Please answer soon as I need to configure this come weekend
[2019-11-02 12:41:17]
[2019-11-02 12:51:04]
Here is the relevant documentation:
Using DTC Server for Data and Trading in Another Sierra Chart Instance: Deleting Sub Instances
Sierra Chart should be on its own dedicated SSD with nothing else. Not even Windows.
Date Time Of Last Edit: 2019-11-02 12:51:16
[2019-11-03 00:24:19]
Oh good, everything regarding sub-instances is as I suspected. Apologies I could not find the documentation myself.
Regarding SC being on its own dedicated SSD. I am installing a seperate NVME for this reason only. Do I just use this as 'storage', with SC also stored there, then access via other SSD?
[2019-11-03 01:18:54]
Sierra Chart needs to be on that NVME along with its Data folder.
