Date/Time: Fri, 03 May 2024 07:27:08 +0000
How do you get the time on the bottom of the chart to show up in 12 hour periods (AM/PM)
View Count: 496
[2019-10-30 21:05:14] |
User918835 - Posts: 2 |
How do you get the time on the bottom of the chart to show up in 12 hour periods (AM/PM) instead of 24 hour clock?
[2019-10-31 00:17:17] |
This is not supported.
