Date/Time: Sun, 19 May 2024 13:08:26 +0000
DOM re-center not working properly
View Count: 703
[2019-10-30 18:04:53] |
User495158 - Posts: 106 |
Hi again! I have multiple DOM windows open across two monitors. Some of these windows are detached. All DOM windows are scaled using auto scaling. I'm using DOM re-centering option to re-center all DOM windows at once. When I do that the recentering line in the middle of the DOM windows is not straight across all DOM windows, rather goes up and down a tick. Please see the screenshot. Thanks! |
dom_recenter.png / V - Attached On 2019-10-30 18:04:46 UTC - Size: 860.02 KB - 265 views |
[2019-12-30 04:20:59] |
We will look this over.
