Date/Time: Wed, 16 Sep 2026 14:11:06 +0000
Use of Sierrachart in own YouTube-Channel
View Count: 937
| [2019-10-30 17:48:05] |
| User549951 - Posts: 5 |
Hello Support-Team! I´ve got a quick kind of legal question: I am about to set up a youtube-channel (in german) which deals with the commodity markets, like news and also analysis. So, as I am using Sierracharts on a daily basis for my trading, I would like to use it for showing the charts there as well. I have no problem mentioning and praising your company in every episode, by the way. Do you see any problem with this or am I good to go? If you are not the right guys to talk to, would you please sent me the correct email-address? Regards Markus |
| [2019-10-30 17:56:54] |
| SC Support - Posts: 2103 |
If you are talking about just using the Sierra Chart Software as the Charting tool to convey your trading ideas, or other analysis, you are certainly free to do this. We will email you to speak further, but we don't see any problem. |
| [2019-10-30 19:24:14] |
Yes this is all perfectly fine. You can do what you want.
