Date/Time: Sat, 04 May 2024 06:07:35 +0000
barchart from CQG
View Count: 858
[2019-10-30 17:05:45] |
frank maderi - Posts: 3 |
hello , I am using CQG and want to move to barcharts as CQG is stopping support in 2020 . how do i do that . thank you in advance
[2019-10-30 19:34:28] |
Stopping support of what? Sierra Chart does work with Barchart but only through our Sierra Chart Exchange Data Feed service: Sierra Chart Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-10-30 19:35:10] |
To begin with, we assume that you will continue to trade through CQG. If you are wanting to access the CME Group of exchanges, then in order to qualify for the lower priced exchange fees, you would need to have a funded trading account. You can get more information on this topic here: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges If you only need data for the CME Group of exchanges, then you would add the Denali Exchange Data Feed. Refer to the documentation here: Denali Exchange Data Feed If you need data from any other exchanges or indices, then you would add the Sierra Chart Exchange Data Feed. Refer to the documentation here: Sierra Chart Exchange Data Feed Once you have the data setup through Sierra Chart, just let your broker know that you will not need the data from CQG. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
