Date/Time: Fri, 03 May 2024 04:37:28 +0000
Symbol VXX19 is not running live
View Count: 821
[2019-10-30 16:04:26] |
User455308 - Posts: 19 |
The chart is not running live. After loading historical, it just stops plotting.
[2019-10-31 00:22:25] |
That symbol is a CBOE futures symbol. Not CME. You will not be able to get real-time data for it.
[2019-10-31 08:37:39] |
Noted. Is there any way to get the CBOE data? What are the extra charges?
