Date/Time: Fri, 03 May 2024 08:11:47 +0000
connection problem
View Count: 482
[2019-10-30 15:49:51] |
User230183 - Posts: 1 |
Hello I have a problem I think I did a wrong manipulation because Allowed Systems: 1 out of a total of 2 system(s) is currently being used. and especially when I try to do a trade on sierra I have an error that appears can you help me please thank you in advance |
[2019-10-30 19:40:48] |
You should see an error in the Trade Service Log. So provide the lines from that when you have the order rejection assuming that is what is happening. Refer to: Support Board Posting Information: Providing Lines From Trade Service Log Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
